Ram usage not going above 50%-60%
Solved by Matt420740,
They are in the black slots.
According to the user manual if you're only running two sticks use the red slots. However what bothers me is that your machine appears to be idling in that screenshot yet is using over 7GB of ram. When at idle I only see around 2.3GB in use. Even during heavy loads and gaming do I rarely ever see 7GB in use, so using that much ram at idle is a concern.
Featured Topics
Fireord36 ·
1
azyrroth ·
Posted in Home Theater Equipment0 -
Andrew john ·
Posted in New Builds and Planning24 -
2
