Max Network Speed?
Go to solution Solved by Vitalius,
Ok so I have a question referring towards optimization. My Isp gives me 15 down and 2 up (mbps) and if I go to a speed test website it says i have that speed. So this is where my question comes in why in apps such as steam, uplay, origin, etc. do I only get 1.8-2 down (mbps)? Is my network properly maximized? I have a direct Cat5E connection to my router my mother board says my Lan adapter does 100 mbps but yet my speeds in these apps are so low. Just wondering if there are any tips to getting more speed out of my network.
-Thanks
Your ISP gives you 15 Megabits per second down and 2 Megabits per second up (Mbps).
You are getting 1.8-2 Megabytes per second down on apps such as steam (MBps).
They're two different things. There are 8 Megabits in 1 Megabyte. So if your ISP were giving you 16 Megabits per second, Steam would show you as downloading at 2 Megabytes per second (because 16 Megabits = 2 Megabytes).
-Thanks
https://linustechtips.com/topic/480049-max-network-speed/
You can have 500 mbps down but still download at 3MB/S
Download speed on speedtest != download speed from servers
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/480049-max-network-speed/#findComment-6439633
-Thanks
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/480049-max-network-speed/#findComment-6439635
Damn, nice ELI5. thanks!
https://linustechtips.com/topic/480049-max-network-speed/#findComment-6439660
https://linustechtips.com/topic/480049-max-network-speed/#findComment-6439690
I usually just take my download peak speed from speed test.net and divide by 8.
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/480049-max-network-speed/#findComment-6439731
As stated before by @Vitalius ,  your ISP provides a data connection. If the internet package is 10Mb (Megabit), the download speed will be approximately 1MB (Megabyte).
8 bits = 1 byte so your theoretical download speed on a 10mb connection will be 1.25MB/s.
But to make life simpler, just divide the internet pacakge speed by 10 and you will a rough estimate of your download speed.
Rig: Thermaltake Urban S71 | MSI Z77 G45-Gaming Intel Core i5 3570K (4.4Ghz @ 1.4v) CM Hyper 212 EVO | Kingston HyperX Fury 8GB | MSI GTX 660 | Kingston 120GB SSD | Seagate 3TB HDD | EVGA 850W B2
https://linustechtips.com/topic/480049-max-network-speed/#findComment-6439747
And furthermore internet traffic has overhead. Typically for every 8 bits there are around 2 bits of encoding and routing data included so real world means that if you actually want to hit 2 Megabytes you are going to need a 20 Megabit pipe.
And beyond even that, the server you are downloading from may be slower than that connection or artificially throttling you. I've never had that happen on steam/origin, but a lot of servers implement caps on it's per-user upload speed.
https://linustechtips.com/topic/480049-max-network-speed/#findComment-6440000
-Thanks
remember this:
b = bit
B = byte                 = 8 bits
M = mega              = 1 000 000
m = milli                 = .001
G = giga                = 1 000 000 000
T = tera                 = 1 000 000 000 000
k = kilo                   = 1000 = 10^3
K = kibi                   = 1024 = 2^10
bit = Binary digIT , a 0 or a 1
mb = millibit           = impossible
Mb =megabit         = 1 000 000 bits
MB = megabyte    = 1 000 000 bytes = 8 000 000 bits
We've now got three different subjects going on, an Asian fox and motorbike fetish, two guys talking about Norway invasions and then some other people talking about body building... This thread is turning into a free for all fetish infested Norwegian circle jerk.
https://linustechtips.com/topic/480049-max-network-speed/#findComment-6440142
-Thanks
follow your topics
https://linustechtips.com/topic/480049-max-network-speed/#findComment-6440203
remember this:
b = bit
B = byte                 = 8 bits
m = milli                 = .001
k = kilo = 1,000 = 10^3 is incorrect. Or at least I've never seen it mean that.
KB is Kilobyte.
Kb is Kilobit.
KiB is Kibibyte.
For reference, see the Wiki page on this:
https://en.wikipedia.org/wiki/Binary_prefix
Note the table on the right:
Ignore JEDEC's prefixes. Those are for Storage (Hard Drives, Solid State Drives, etc.) as opposed to Internet Speed.
https://linustechtips.com/topic/480049-max-network-speed/#findComment-6441624
