benefits of E-atx vs atx?
Go to solution Solved by Glenwing,
for example, the asus Rampage vs the maximus viii?
There's no inherent benefit. If you have an ATX board and an E-ATX board that have exactly the same features and such, there won't be any benefit. Usually E-ATX boards do have more features, which is why they are E-ATX, because they couldn't fit everything in the normal ATX form factor. So those boards would be better but it's not being E-ATX that makes them better. The form factor itself doesn't do anything.
my first build ^~^ cpu: core i5 6500
mobo: Asrock h110-itx
gpu: r9 380
8 gigs ddr4
psu: corsair cx 500
case:thermaltake core v1
usually has more PCI-e and other connectors.
Typically it allows for things like more fan headers, with some better layout of components due to more room. It doesn't really do anything for performance, it's just a little more room.
ok thanks guys!
gpu: r9 380
8 gigs ddr4
psu: corsair cx 500
thank you kind gentleman and or woman, thank you very much :P
gpu: r9 380
8 gigs ddr4
psu: corsair cx 500
boards no, but cases yes, E-ATX case gives you more room to work with. less cramped. And no need to worry about will this gpu fit into my case. Corsair 900D fits a HPTX and that's much larger than a E-ATX.
Intel Xeon E5 1650 v3 @ 3.5GHz 6C:12T / CM212 Evo / Asus X99 Deluxe / 16GB (4x4GB) DDR4 3000 Trident-Z / Samsung 850 Pro 256GB / Intel 335 240GB / WD Red 2 & 3TB / Antec 850w / RTX 2070 / Win10 Pro x64
HP Envy X360 15: Intel Core i5 8250U @ 1.6GHz 4C:8T / 8GB DDR4 / Intel UHD620 + Nvidia GeForce MX150 4GB / Intel 120GB SSD / Win10 Pro x64
HP Envy x360 BP series Intel 8th gen
AMD ThreadRipper 2!
5820K & 6800K 3-way SLI mobo support list
