Cooling for i7-6700k
gouran
well... H110i GT or GTX
So which will be better?
Poland poor country.
CPU: I7-6700k, MOBO: Asus Maximus VIII Hero, PSU: EVGA SUPERNOVA P2 1000W, GPU: Geforce GTX 1080, RAM: HyperX Savage DDR4 16GB 2800MHz, CASE: Corsair obsidian 900D, SSD: Samsung 850 EVO 250GB, HDD 3TB WD green, COOLER: Corsair hydro series H110I GT
There isn't really a difference between those two apart from the colour things you get on the block.
The NZXT Kraken X61 would be a good choice. I would suggest the Noctua NH-D15 as it cools like a BEAST, but you think it's ugly. I think it looks good, but I'm in the minority.
An alternative air cooler that has good performance would be the bequiet! Dark Rock 3. Not as good as the NH-D15, but a lot of people agree that it looks better. I disagree, but again, I'm the minority.
You could get the Noctua NH-D14 (the NH-D15 predecessor) and stick Noctua NF-P14 redux fans (they're grey) on it, then at least you won't have to look the signature poop brown and vomit tan Noctua fans.
EDIT: I've just remembered that there are some 360mm AIO coolers on the market. I've just found such an example. http://www.amazon.com/Thermaltake-Ultimate-Enthusiast-Cooling-CL-W007-PL12BL-A/dp/B00MPIDYTO
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
In tests h110i gt is better then this thermaltake http://www.hardocp.com/article/2015/03/11/corsair_hydro_h110i_gt_ext_perf_aio_cpu_cooler_review/3#.VhFHfPntlBc
So better take pro3 then h110i gt?
That link shows the H110i GT is better at stock, but the Thermaltake Water 3.0 Ultimate is better when overclocked and audio tests.
When I jump into watercooling, I'll be building a custom loop as you have greater customisability. Until them, I'm sticking with my NH-D15. But that's just me.
Incipere V5.0
Parvulus V1.0
The difference is so miniscule i don't see the triple rad being justified. Just get a corsair H110i GT/GTX or a NZXT Kraken X61 and use the rest of the budget on really good fans, like Noctua NF-A14s or Venturis
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
I'm thinking about Air Series AF140
Don't get those...they are barely average. Good fans are worth investing in, trust me.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
Venturi 12/14?
What if wc broke? Did this water can make short circuit?
Venturi 12/14?
venturi hp-14 pwm
And leaks are a risk, a tiny one, but something to consider. I recomend inspecting the unit before installing it, nowadays they come with long warraties, but inspect it before using anyway since, water on your mobo/GPU would be disastrous
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
venturi hp-14 pwm
So it's lotery it can brake in about 2 years and breake my pc?
It's VERY rare, it has happened, but i've also seen motherboards break over heavy heatsinks, all solutions have some degree of risk, but given the overall experience people have had with AIOs i would say they are very safe for the most part. As long as you don't buy one that is known to have issues like the cooler master Glacer 240, corsair in general is very, very reliable.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
But there is some % that it can destroy my pc and warranty won't fix it?
In conclusion air cooling is safer
Yeah, it is safer, but i insist that the risk with an AIO is very small nowadays, i wouldn't have one my PC otherwise.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
Is that true those AIO are very laud and it's good to change fans?
For the most part, yes. Corsair specially makes very good coolers but ships very loud fans.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
Now I am at a loss betwen DRP3 or 110i gt DRP3 won't burn my pc but higher temparuteres, 110i can burn up my pc but lower temperatues...
