Hey guys i was just looking for helt to find me a good gpu and those 2 gpus being the MSI R9 390 or MSI Gtx 970 that is both good and could also match with my build if you want the specs of my build im gonna do in the soon future (1-3months) just ask and if i dont get the pc in about 1-3 months its gonna be in the summer.
My PSU is 650w EVGA G2 80+ gold efficiant and should i overclock both of them or just stay with normal clockpower
Selling a MSI GTX 550ti in stockholm sweden or looking for free pc parts in Stockholm sweden
https://linustechtips.com/topic/458017-help-me-pick-between-2-graphics-card/
R9 390
GTX 970
      CPUIntel Core i7-4790K 4.8GHz Moherboard: MSI Z97 SLI Krait Edition Memory: HyperX FURY White 24GB DDR3 1866MHz GPU: Asus GTX 970 Turbo
             PSU: EVGA SuperNOVA 750w SSD: Crucial MX200 250GB HDDWB Blue 1TB Monitor: (2x) BenQ GL2460HM 24-Inch Case: NZXT S340 White
r9 390 is slightly faster
GTX970 is more energy efficient
all other differences are personal preference. (they're priced identical in my area, like to the cent identical.)
390
- more vram
-better performance
-more heat
-more power draw
970
-less vram
-about same performance at 1080p  but lower in higher res
- so far less dx 12 performance
-less power draw
-less heat
- decent overclockers
i own a 970 and not a 390 so i can only truly say stuff about the 970 and the 390 is based off of benchmarks and videos
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
Are you doing High Res stuff? If so the r9 380. But you should just get the R9 390 if heat and power isnt an issue
My i5 6500 is bad and can't even maintain 4.5ghz, and 4.4ghz causes it to slowly become unstable over weeks with a vcore of 1.395. FML
1080p, go with the GTX 970
1440p and higher, R9 390
I'm having to sell my GTX 970 as its vRAM isn't enough, and some (not all) games seem to be only able to use 3.5GB of vRAM when Minecraft has no problems.
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
At 1080p quite a few games push 5-6GB of VRAM usage - I'd say 390 across the board
3x 1440p.
resolution isnt an issue.
vram hogging games are.
at the same time theres games that dont pull more than 2 at 3x 1440p
Only a handful - devs are too lazy to optimize
pick your devs carefully.
or have an odd taste in games...
"Long Live the Queen" - check it out :P
I have my GTX 650ti OC 2GB running out of vRAM at 1024x768-4GB of vRAM is nothing to higher resolutions.
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
The r9 390 is way better, now, and 3 years from now! Also keep in mind, there are no such things as "more energy efficient" "more power draw" ONLY an fanboy would come up with such things haha.. With both cards you need a big PSU. No matter what rig you have, it is always better to have more power even if you don´t use it. In any resolution you will play the r9 390 will do more than perfect!
There are such things as graphics cards more efficient than others, and ones that consume less power than another. As for the PSU, the R9 390 does need a bigger one-and its not perfect at 1080p and below.
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
You can't go wrong either way really, I would go with r9 390 b/c of mantle
Mantle. The API that AMD stopped development on.
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
Did it really? In that case, I wouldn't know what card to pick. Since they are pretty much similar, it would probably come down to what color you like
Just don't use Mantle as a point when recommending any of AMD's cards-its defunct now
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
mantle is kinda 'dead'. it's remains live in the vulcan api now, and if we are lucky devs are switching from dx11 to vulcan instead of dx12
Lmao not Gona happen
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
hmm.. I think I mentioned, it is always better to have a bigger PSU than the required for any part in your sistem! ..the thing with power draw is getting so old and stinky u.u ( an r9 390X will consume per year around $17/15€ while a GTX 970 $11/9.7€) So, you pay like nothing, amount of money that you don´t notice it BUT you do notice the amount of FPS of r9 390!
