Hi guys, yesterday i got my new case and everything went well transferring all components from my old case to my new case, however when i power it this happens.....
https://youtu.be/WSn8a7WXaHA.
I've tried googling but haven't really gotten any answers. Also i tried switching ram which didn't work, so it's not fried ram i should be worried about.
Please help im dying without my pc..
https://linustechtips.com/topic/449763-ehm-i-have-run-into-a-problem/
Did you plug the HDMI/Displayport/whatever cable directly into the GPU instead of the motherboard?
Project Pluto
i3 4170 MSI H97 PC Mate MSI R9 380 2GD5T @ 1095MHz Kingston HyperX Fury Blue 2x4gb @ 1600MhzWD 1TB Blue • be quiet! Pure Rock • NZXT S340 Black XFX TS 550w • BenQ GW2265HM
I take it that the only thing that has changed is the case? Double check ALL connections and component seating first. If you need to, completely dismantle and rebuild. Is there any chance that you could have pinched a cable with a screw somewhere?
^this, 10/10
Try uploading another video, of the inside of the case. film it in a well lit environment so we can see if anything isn't plugged in.  (like the 4pin CPU power cable, etc)
Dubs are better than subs
The guy below, @Mattyd7829, has the best answer and for the love of god...please remover you underwear from your videos...I DON"T WANT TO SEE WHERE YOUR CROTCH HAS BEEN!
A water-cooled mid-tier gaming PC.
Unless I'm mistaken that's a dead motherboard.  It clicks on and off like that, meaning that is most likely the problem.  Alternatively it could be the PSU, it may not be outputting enough juice, or it's just dying.  In all likelihood that is a dead motherboard btw watch Linus' video on making the router, spoiler alert, his mobo dies and I kinda guessed it before he said because when he tried to power it on something very similar to what is happening to you, happened to him.
I'm playing my Xbone on 3 LG Curved monitors-No one ever
Please, read CoC it helps, it helped me it should help you-Every competent member
Resident bad pun maker.....please excuse them
Another thing that maybe happening, is that everything isn't firmly plugged in and that could be the issue.  Make sure everything is plugged in, and if it doesn't work I'm gonna say that's a dead motherboard.
Did you reset the CMOS? It's possible the case intrusion thing is acting funny.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
how does one reset the CMOS, my motherboard is the asus p8z68-v
There is somewhere a button battery, remove that and pull the power cord for a couple of seconds, take 30-60 seconds to be sure. After that put the power cord back and put the battery back and try to boot again.
