I haven't looked into this at all but I was watching a video from JaysTwoCents and he mentioned ASIC quality now I know that the higher the number generally the better OC you can get with lower voltages and lower temps but what is the average percentage.
Yesterday reinstalled my GTX 780 and it scores an ASIC quality of 72% and I have no idea if that is any good though since I have no plans to overclock it doesn't really mean much to me but I'm just wondering out of curiosity.
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
https://linustechtips.com/topic/440854-asic-quality-question/
It's about average. Scoring in the low 70's is average I would say.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/440854-asic-quality-question/#findComment-5908776
It's alright, in that video J2C said that 80 or something is the highest usually, and 65 or something is lowest usually..
But it's not the be all and end all (is that spelled right??) of you GPU and its OC'ing capability.
https://linustechtips.com/topic/440854-asic-quality-question/#findComment-5908786
Average - above aberage is 80% and up.
https://linustechtips.com/topic/440854-asic-quality-question/#findComment-5908789
Ahh, I thought the GTX 780 Lightnings were special, damn you MSI lol
https://linustechtips.com/topic/440854-asic-quality-question/#findComment-5908810
Nope - it's completely random usually - EVGA recently started selling Kingpins based on ASIC but up until that it's all RNGesus' working.
Case in point - I have a 280 and a firned has a 280X both by asus - mine has 77% - his 72% - luck - then again - mine is dying as we speak so luck ^_^
https://linustechtips.com/topic/440854-asic-quality-question/#findComment-5908844
I wouldn't get too worked up over it, the silicon lottery matters far more than ASIC quality. You could have 90% ASIC quality but if you get unlucky with the Silicon lotto then it wont make a difference.
https://linustechtips.com/topic/440854-asic-quality-question/#findComment-5908847
how can i see the ASIC quality?
https://linustechtips.com/topic/440854-asic-quality-question/#findComment-5908864
GPU-Z
https://linustechtips.com/topic/440854-asic-quality-question/#findComment-5908866
Top left corner of GPU-Z right click then read ASIC quality.
https://linustechtips.com/topic/440854-asic-quality-question/#findComment-5908870
my 970 is 65.5% :(
https://linustechtips.com/topic/440854-asic-quality-question/#findComment-5908912
I am blind
Do you see the icon in the top left hand corner of GPU-Z? Click on it and it should bring up a menu. There should be an option for checking ASIC quality.
https://linustechtips.com/topic/440854-asic-quality-question/#findComment-5909075
Right click the top left and then you'll get this menu:
my ASIC quality is 73.1 on a EVGA gtx 970 SC, is that good?
https://linustechtips.com/topic/440854-asic-quality-question/#findComment-5909098
Not going to say if it's good or not, but my Windforce 970 has 77.7%.
https://linustechtips.com/topic/440854-asic-quality-question/#findComment-5909190
My msi 970 has 74.2%, I recall someone on this forum said he had an old nvidia card with an 92% Asic quality.
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
https://linustechtips.com/topic/440854-asic-quality-question/#findComment-5909507
