i personally would avoid them like the plague, you dont know what kind of conditions they were used in
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/435271-second-hand-tech/#findComment-5833957
Sometimes I do, mostly games and gaming related items though.
But it's not a super scary thing to do, as long as you can see the item in working condition and you know what the previous owner has done with it (no bitcoin mining, extreme overclocking, etc.)
https://linustechtips.com/topic/435271-second-hand-tech/#findComment-5833966
I bought my Cooler Master HAF X secondhand for about $70. Just be sure to inspect the part fully and stress test it to make sure it is still in mint condition. A bonus would be having the receipt, the original box and accessories. It shows pride and care of ownership.
So look at local craigslist and listings so that you can physically meetup for the inspection and testing. Dont do ebay.
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
https://linustechtips.com/topic/435271-second-hand-tech/#findComment-5833968
buying second hand games is like piracy...the developer gets no money
https://linustechtips.com/topic/435271-second-hand-tech/#findComment-5833987
Got a 2nd hand lappy - not a bad deal - so far it works fine, aside from a dead battery
https://linustechtips.com/topic/435271-second-hand-tech/#findComment-5834021
When you buy a Second Hand tech, Just avoid it buying from eBay or some sites. If you trust them so much, Buy.
Get it from someone you know, So that you could ask questions to them if the tech is not good.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/435271-second-hand-tech/#findComment-5834028
All my main sort of components are brand new, but my monitors were all used, and all of them work fine. But of course YMMV.
Normandy - Intel Core i5 3470, 8 GB Corsair Vengenace LP, EVGA GTX 960 SSC, Gigabyte GA-Z77M-D3H-MVP, WD Blue 1 TB, Seagate 320 GB (steam), Seagate 320 GB (experimental, second OS, etc), Windows 8.1 + Ubuntu 14.10
Garrus - HP Stream 11
https://linustechtips.com/topic/435271-second-hand-tech/#findComment-5834039
They are not selling the game new in many cases, so they wouldn't make money off of it anyways.
It's like pirating NES games, Nintendo doesn't make money off of NES products.
And also, pirating is duplicating a product and distributing it for free, while you yourself still have the product.. 2nd hand games are never duplicated :P they just go from 1 owner to another. That's like someone selling their Steam account, the games go from one person to another and the first person doesn't have the games anymore.
https://linustechtips.com/topic/435271-second-hand-tech/#findComment-5834053
Depends on what it is?
Used hard drive? No
Used SSD? Maybe
Use graphics card? sure!
I also buy waterblocks, but only nickel ones. Copper is kinda sketchy used
Specs: 4790k | Asus Z-97 Pro Wifi | MX100 512GB SSD | NZXT H440 Plastidipped Black | Dark Rock 3 CPU Cooler | MSI 290x Lightning | EVGA 850 G2 | 3x Noctua Industrial NF-F12's
Bought a powermac G5, expect a mod log sometime in 2015
Corsair is overrated, and Anime is ruined by the people who watch it
https://linustechtips.com/topic/435271-second-hand-tech/#findComment-5834163
I'd buy 2nd hand monitors and cases... and maybe monitor mounts...
I could get better monitors for cheap that way...
https://linustechtips.com/topic/435271-second-hand-tech/#findComment-5834174
Used SSD? Maybe
Depends on capacity. Anything under 240GB and its probs almost entirely worn out
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
https://linustechtips.com/topic/435271-second-hand-tech/#findComment-5834183
SSDs under 240 can still write into the petabyte
https://linustechtips.com/topic/435271-second-hand-tech/#findComment-5834339
True that but don't forget the r/w speeds drop over time also, and you never know what kind of usage conditions the last owner imposed on the SSD ph34r.png
Speedtests
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
Type            Server
OS              Ubuntu 14.04 LTS
RAM             2GB Non-ECC
Quotes of Fame
https://linustechtips.com/topic/435271-second-hand-tech/#findComment-5834357
Two GTX 660s that i got second hand worked great.
Sitting on my desk now. As an ornament.
Might try and get used/nearly new WC gear.
https://linustechtips.com/topic/435271-second-hand-tech/#findComment-5834358
good point, but if you can (if it is sold on steam official website or somewhere else) I would buy a game as new, and (in my opinion) selling steam accounts is nearly the same to pirating, and sometimes the "second hand games" are just pirated and put onto discs.And about Nintendo games, I am really wondering why Nintendo isn't selling them (I will research online when I have time but I won't get them because I never pirated any Nintendo games and I want to keep it that way)
https://linustechtips.com/topic/435271-second-hand-tech/#findComment-5834361
Well Nintendo isn't selling most NES. SNES, N64 ,etc. games anymore. Sure, there are exceptions like they sell Super Mario Bros. in their Virtual Console and they remade games like Majora's Mask and Ocarina of Time.. But most games are not remade or redistributed.
And I often go to thrift shops, pawn shops and flea markets buying 2nd hand games. Because I like collecting and 99% of the games are not sold new anymore.
Fun fact: I just came home after going to a pawn shop. Bought a couple PS1 and PS2 games.
https://linustechtips.com/topic/435271-second-hand-tech/#findComment-5834445
wow, thanks for educating me about the Nintendo games
I hope you will have fun playing the PS1 and PS2 games :)
https://linustechtips.com/topic/435271-second-hand-tech/#findComment-5834531
