Nvidia Geforce GTX 770 Review (after 13 months of usage)
AlTech
In June 2014 I bought an Nvidia Geforce GTX 770 with 2GB of VRAM for $349 US dollars. 13 months later it is $329 on Newegg at the time of this review you should not buy it. 6 months ago it was a great deal, it performed well and not like the average high end graphics card today.
In many games, I often had major frustrations because of the measly 2GB which force me to use 1080p at high settings with some custom modifications to them. Instead, I would rather play at Ultra settings or at high settings at DSR (Dynamic Super Resolution), which by the way is awesome and I wish every game supported.
In 2015, 2 years after its launch, it is still the same price it was released at which makes me wonder why Nvidia even keeps it around even when the successor (Geforce GTX 970) has been out for more than 4 months. The only reason I could find was that they needed something priced the similar to the AMD Radeon R9 285 which costs about $299-$329 while delivering better performance.
In battlefield 4, while playing at high settings I had no trouble maintaining more than 60 fps and often got around 90-100 fps with a maximum of 130 fps. However, in minecraft I found that I was getting an average of about 60 fps and got around 130 fps maximum. This result really shocked me as minecraft is supposed to be an easy to run game for even the most mediocre hardware and it led me to believe that minecraft is not at all optimized.
All this led me to the conclusion that the Geforce GTX 770 is not worth it anymore and despite being one of my favorite graphics cards of 2014 in terms of value for money, it no longer holds that position and I no longer recommend it. For less money, you can buy a Geforce GTX 960 which features all the new technology in second generation Maxwell architecture like VXGI (Voxel Global Illumination). On the other hand you can also get the new Geforce GTX 970 for the same price. It features double the vram, 4.3% more cuda cores, 10% more performance, 18% less texture mapping units, 75% more render outputs and 37% less power consumption.
The Good: Decent performance in AAA titles.
The Bad: Value/money and mediocre performance while playing non demanding games.
The Ugly: Price and  low vram quantity.
Edited by AluminiumTech
Fixed text formatting 5 years late
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
A tip, the Cuda Cores on the GTX 970 aren't only more, but they're more efficient, in fact, the 970 beats the 780, even if it has less cuda cores (1664 vs 2304) they are more efficient, so it takes less cudas on Maxwell to equal Kepler's performance.
|| Asrock Z68 Extreme 3 Gen 3 || i5 3570 @3.5GHz || Zalman CNPS10X Optima || 8GB RAM HyperX Fury Blue @ 1600MHz || Thermaltake Berlin 630W || Zalman Z11 || Gainward Phantom GTX 970 || 120GB Kingston V300  (Gift) + 1TB  WD Green
Phone: Xiaomi Redmi Note 8
Tablet: iPad Mini 2
Interesting.
On a side note, i'm still using the msi gtx 770 2gb myself. Was thinking about 970 or 980ti for 1080 but i guess 980ti is an overkill.
Interesting.
I'm waiting for GTX 1070/1080.
Yeah but many youtubers have complained that fewer cuda cores = worse performance in professional applications.
Side note - It's hilarious how bad vanilla minecraft runs on this.
As for modded minecraft, it's a joke xD
Considering I got mine for cheaper than a 960 the other month, I'm actually quite pleased with it for a "short term" graphics card. It has pretty good performance and OCs decently, and although I haven't ran out of VRAM yet, my usage is quite high. If you can get a 770 for around or less than a 960 then it's a steal if you ask me, but more than a 960 and it becomes worthless.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
Minecraft is cpu intensive, I always had above 60 fps 1080p with a 3rd gen i5 and no gpu.
Also my 760 has gone up from $170 when I bought it to over $300.
http://www.amazon.com/dp/B00DIH8OUK/?tag=pcpapi-20
http://pcpartpicker.com/p/9DNjLk I like the night theme, it complements my dark basement. If you are reading this then you must also be a fan of the night theme.
01011011 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01001000 01100101 01110010 01100101 01011101
I have a 4th Gen i5, and it stutters when im loading the AMPLIFIED biomes on max render distance. Though it is well above 60 with shaders, GTX 970.
Quote me if you want me to see your message. Like my post if it helped. Click "Show More" to see things that I use.
Desktop (2014): CPU: Intel Core i5 4690k @ 3.50GHz | GPU: MSi GTX 970 Gaming 4G | Motherboard: MSi Z97 Gaming 5 | RAM: 2x4GB G.Skill RipJaws X 1600MHz + 2x4GB HyperX Black 1600MHz | SSD: Samsung 750 Evo 120GB | HDD: WD Black 1TB | Cooler: Cooler Master Hyper 212x | PSU: Corsair VS650 | Case: Cooler Master Elite 431 Plus | OS: Windows 10 Home
Laptop (2017): Model: Asus UX310U
Peripherals: Monitor: Samsung S24D300 OC@75Hz + Viewsonic XG2401 (144Hz) | Mouse: Logitech G305 | Keyboard: Razer Blackwidow Chroma V2 | Headset: HyperX Cloud Core | Speakers: Logitech Z333 | Additional: Logitech G29
Mobiles: Samsung Pixon (2010-2012) | Samsung Galaxy Ace (2012-2013) | Samsung Galaxy S3 (2013-2016) | Samsung Note 4 (2015)(Lost) | Samsung Galaxy S7 (2016-2019) | Samsung Galaxy S10 (2019 - Current) | Additional: ASUS Zenwatch 2 (2016)
Maybe it was because I was playing with normal terrain on normal render distance. Also could be storage related if you are loading lots of land at once.
I got my 770 2GB for €380 at launch.... Hefty price for 770 but there was Bitcoin craze going around back then and 7970 was almost €500 and GTX 680 also.
In terms of price, for the most part if youre in the market for a GTX 770 you should probably be looking at the used market at this point.
Obviously the retailers like Newegg, etc... arent gonna drop the price, if anything theyll raise it to turn you off from buying it, theyd rather sell you a newer card and either way, Nvidia cards really never drop in price when theyre being sold as new anyway.
I also have a 4th gen i5 but Amplified doesn't stutter a lot
Nice review OP. The 2gb limit is really the only reason I would upgrade my 770. It runs great for pretty much every game I play with the exception of the newer AAA memory hog titles.
Main Rig: CPU i7-4790k / MOBO Asus Z97-Pro (Wifi-AC) / RAM 16GB HyperX Fury 1866 MHz / CPU COOLER Dark Rock 3 / GPU Asus GTX 1070 Strix  / CASE Evolv ATX Tempered Glass / SSD Crucial MX200 250GB / HDD  WD Black 1TB + WD Blue 3TB / PSU EVGA 750G2 / DISPLAYS 2x Dell U2414h / KEYBOARD Corsair K70 RGB Cherry MX Brown / MOUSE Logitech G602
Laptop: Dell XPS 15 / i7-6700HQ, 16GB RAM, 512GB SSD, GTX 960m, 1080P Display
Cheap Windows/Office Keys
i got a 770 Windforce, it does just fine. If I ever needed more in the short term, I think I might just go for used 770 for SLI (used for around $200) as a stop gap until nvidia has HBM
2017 Macbook Pro 15 inch
Would you explain me this? How is bad value when playing "non demanding games"
Because you can get similar performance much cheaper or get much better for a small premium.
Main Gaming PC - i9 10850k @ 5GHz - EVGA XC Ultra 2080ti with Heatkiller 4 - Asrock Z490 Taichi - Corsair H115i - 32GB GSkill Ripjaws V 3600 CL16 OC'd to 3733 - HX850i - Samsung NVME 256GB SSD - Samsung 3.2TB PCIe 8x Enterprise NVMe - Toshiba 3TB 7200RPM HD - Lian Li Air
Proxmox Server - i7 8700k @ 4.5Ghz - 32GB EVGA 3000 CL15 OC'd to 3200 - Asus Strix Z370-E Gaming - Oracle F80 800GB Enterprise SSD, LSI SAS running 3 4TB and 2 6TB (Both Raid Z0), Samsung 840Pro 120GB - Phanteks Enthoo Pro
Super Server - i9 7980Xe @ 4.5GHz - 64GB 3200MHz Cl16 - Asrock X299 Professional - Nvidia Telsa K20 -Sandisk 512GB Enterprise SATA SSD, 128GB Seagate SATA SSD, 1.5TB WD Green (Over 9 years of power on time) - Phanteks Enthoo Pro 2
Laptop - 2019 Macbook Pro 16" - i7 - 16GB - 512GB - 5500M 8GB - Thermal Pads and Graphite Tape modded
Smart Phones - iPhone X - 64GB, AT&T, iOS 13.3 iPhone 6 : 16gb, AT&T, iOS 12 iPhone 4 : 16gb, AT&T Go Phone, iOS 7.1.1 Jailbroken. iPhone 3G : 8gb, AT&T Go Phone, iOS 4.2.1 Jailbroken.
Well, i dont agree on that. I mean if he is talking of the card being overkill for "non demanding games", i would argue that since DSR is here, almost any game can be hard to run, of course im not saying that counter strike 1.6 on 4k will get 99% gpu usage, but things like skyrim, and suck on 4k can be very demanding
In the other hand, if we are talking on games like hearthstone... well you can run that on a cellphone, so by that argument you might as well get a HD 5450
Same ^_^
I don't agree simply based on the fact that I bought the 4 Gb version and that I paid $237 with tax and shipping. The card is worth what you decide to pay for it in my opinion. When they first came out, was it worth the money....heck no. I used a 7850 for a long time but I needed some more GPU power in 2015. I think running The Witcher 3 and not dipping below 30 fps using some Ultra settings and some high is perfectly acceptable. I even use Hairworks. I just tweaked the ini file. I got mostly a steady 45-57 and I lock my fps to 57 in rivatuner. It maxes out Bioshock Ultra everything running solid 60fps in 1080p. That's good enough for me.  I really wanted the 780 Ti but I didn't want a 3Gb card, I wanted a 4 Gb card and the 780 Ti when I bought this was WAY too much for what it was worth in my opinion. Some guys wanted $400 for them and the 970 was already out, lol. If not for Ramgate I'd have bought the 970 though.
I'm running MC with medium shaders, milleniare and most of the main mods off a GTX 970 and i5 4440, and after a while hovering at 85fps (limit of the monitor) the performance drops to sub 50fps, and I'm only playing at 1024x768. MC just plain sucks now when it comes to what runs it well.
"We also blind small animals with cosmetics.
We do not sell cosmetics. We just blind animals."
"Please don't mistake us for Equifax. Those fuckers are evil"
This PSA brought to you by Equifacks.
PMSL
Same ^_^
I did not state a lot. I just meant a little, like every 3 seconds or so.
Oh my, I didn't know that. I always assumed my old 680 was still better for computing than a single of my new 970's, because it had more cuda cores.
"It's a taxi, it has a FARE METER."
The 970 still has more cuda cores (1664 vs 1536 of the 680).
Tablet: iPad Mini 2
Woops, you're right, I was under the impression the 680 had 2048 for some reason.
