*High Quality* audio cables
FrigidNinja
Go to solution Solved by xeromynd,
Never had a problem with Monoprice cabling, I'm sure they have what you need.
The 'sounding worse' OP is referring to is probably just shitty shielding.
I'm looking for some decent audio cables for my car stereo. I'm looking for a rather short RCA cable, a female RCA to female headphone jack, headphone jack splitter, and a rather long headphone cable (ill need 2)
I realize Linus has talked about the 'super cable' myth but I'm pretty sure there are some legitimately superior cables out there.
Budget is about $50 total. Thanks!
Why do you need three things? Can't you just get a cable that has two different connectors?
There aren't better cables for audio. Just like for video, there are normal cables that perform as advertised and there are shitty cheap cables that you avoid. Anything else is snake oil
Its either one statement or the other, if its a digital cable it just works or it doesnt, period.
Analog is a different matter entirely
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
The only benefit to spending more on cables of any sort is superior build quality. More robust connectors, better shielding and maybe braided cables. You get the idea
Feel free to message me if you want to chat!
Monoprice or Parts Express are good places to shop although PE will sell you $50 gold plated connectors if you let them (they never say they are better than the $5 ones however).  Durable, "twisted", heavy gauge?  You could go DIY and use one of my favorites, Canare 4s11.  Google it and buy it in "bulk", by the foot.
System: i5 6600K@3.6 GHz, Gigabyte Z170XP SLI, 2x8 Corsair DDR 3000, Corsair Hydro H60i cooler, Rosewill CAPSTONE 750w Gold PSU, 1x 512GB SSD, 1x 2TB 7200RPM, Windows 10 Pro x64
Display: XFX R9 390 DD, triple 1920x1200 24" HP monitors (5760x1200 @ 60Hz)   Sound: Audio-gd NFB-11 -> AKG K7XX or 2.1 speaker system
For example, i have a headphone cable that i ordered from china and a cable that came with some sony headphones. the Chinese cable sounds significantly worse than the Sony cable.
that's completely unrelated to spending more or less for a cable. It may just be that the jack doesn't fit as well and isn't actually properly inserted, pushing it harder may solve the issue.
Still, that would be an analog cable, so subject to SOME difference. A digital cable is completely devoid of such differences.
sudo chmod -R 000 /*
Well oxygen free can improve the cable, not the sound. There is also the whole build quality aspect. And no you dont know what I do with my cables ;):P
lol yea that SD card thing
Build quality sure, but is not like you're going to use a cable as a rope to lift several kilograms xD.
I just hope that the people here are not like those audiophiles who spend thousands on a freaking cable, the things I've seen on other websites are scary as far as audio goes lol.
The stars died for you to be here today.
A locked bathroom in the right place can make all the difference in the world.
As I said you dont know what I do with my cables. I mean I have a USB cables sleeved in aramid armor.
That's some fancy stuff.
I'm staring at your username.
Blue Jay
CPU: Intel Core i7 6700k (OC'd 4.4GHz) Cooler: CM Hyper 212 Evo Mobo: MSI Z170A Gaming Pro Carbon GPU: EVGA GTX 950 SSC RAM: Crucial Ballistix Sport 8GB (1x8GB) SSD: Samsung 850 EVO 250 GB HDD: Seagate Barracuda 1TB Case: NZXT S340 Black/Blue PSU: Corsair CX430M
Other Stuff
Monitor: Acer H236HL BID Mouse: Logitech G502 Proteus Spectrum Keyboard: I don't even know Mouse Pad: SteelSeries QcK Headset: Turtle Beach X12
GitHub
Is it weird or something? xD.
It is isnt it.
Price will never directly correspond with quality, however, as a general rule of thumb, if you spend more on somthing made by a reputable manufacturer youre less likely to have manufacturing problems... such as the cable not fitting properly.
anyway i ordered everything from monoprice. Thanks to Xeromynd and TheProfosist.
no problem man
