*High Quality* audio cables
Solved by xeromynd,
Never had a problem with Monoprice cabling, I'm sure they have what you need.
The 'sounding worse' OP is referring to is probably just shitty shielding.
I'm looking for some decent audio cables for my car stereo. I'm looking for a rather short RCA cable, a female RCA to female headphone jack, headphone jack splitter, and a rather long headphone cable (ill need 2)
I realize Linus has talked about the 'super cable' myth but I'm pretty sure there are some legitimately superior cables out there.
Budget is about $50 total. Thanks!
Why do you need three things? Can't you just get a cable that has two different connectors?
