Worse than a 960?!?!?
Solved by harrynowl,
But the GHz is less than the cpu I just had
Gigahertz isn't everything, just like BHP isn't everything in a car
As you can see at the same clock speed the i5 4690k absolutely bags the FX cpus (on a single core). Which is why simply looking at cores and GHz is misleading
I'd look at something like an i5 4460.
Oh and also; the GTX960 isn't 960MHz and the GTX970 isn't 970MHz- that isn't how they are named.
