4.69 mbps and 3.14 mbps
Hi guys I have really slow internet speed as you can see. The reason why my ping is high though is because im downloading something right now. I have a Asus dual band wireless adapter and its really good, so my network card cant be the problem.
http://www.amazon.com/Dual-Band-Wireless-AC1900-PCI-E-Adapter-PCE-AC68/dp/B00F42V83C/ref=sr_1_1?ie=UTF8&qid=1432783378&sr=8-1&keywords=asus++pci
My ISP grants me 60 MBPS download and upload so I don't think that's the problem either.
What could possible be a problem though is my router. I've had that router since our house got the first computer which was like maybe 7-8 years ago. its a Netgear.
Also, other people using the internet is not the problem because no one uses besides my mom and I and shes not using it right now.
Keep in mind that I don't have other internet issues. My games doesn't lag, internet's fine. But when I download something, it take ages. It took my like 15 just to download GTA 5.
What could be the problem?
https://linustechtips.com/topic/375123-internet-help-please-help-a-friend/
Stop all downloads (and seeding if you do that), and re-run.
Whats your router?
Whats your network adapter?
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
is this wifi?
So wait, what speeds are you getting currently, do a speed test.
CPU:AMD FX-8350 @ 4.4 Ghz  - Motherboard:Gigabyte GA-990FXA-UD3 - RAM:Kingston Hyper X Blu - 8GB - GPU:Gigabyte GTX 760 - Case:NZXT H440 Red & Black - SSD:Kingston Digital 120GB - HDD:(2) Western Digital 1TB Blue - PSU:Thermaltake Smart 650W 80 PLUS Bronze - Keyboard:Corsair Vengeance K95 RGB - Mouse:Corsair M45
Try plugging into your modem/direct line through ethernet and post the speeds then without any downloading or network traffic. This could rule out your router.
CPU: Intel i7 4790k  Motherboard: MSI Z97S Sli Krait Edition  RAM: 16GB Kingston Hyperx Fury (black)  GPU: Gigabyte Geforce GTX970
Case: Coolermaster Mastercase Pro 5  Storage: 1TB WD 120GB Samsung OSD  PSU: Corsair RM750  Monitor: Acer 23"
KeyboardCM Storm Quickfire TK Cherry MX Blue  OS: Windows 10     Working on hardline watercooling!  :D
If your router is old, it might not take full advantage of your wireless card. Different technologies have different standards. Also wifi signals are going through walls and other things through your house. Try a wired connection with a laptop and test the speed of the wifi or go closer with a tablet or phone and test the speed.
Might be the router might be something else.
How far is your computer with the network adapter from the router?
yes sir
then if you want good speeds stop using wifi
well your internet sorta sucks, you should get better.
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
Hey Hellbringer3110,
Seems like you have a awesome Network card! But it seems as if your network card is not being utilized to it's full potential.
The issue here is that your network card supports up to AC. Which is actually great! You'll be getting amazing speeds even if you're on wifi. (Unless you're 100ft away with
walls in between)
But.... Your router is outdated. It does not fully support the wireless card. You can search for a firmware update for your router/modem and perhaps there shall be some MINOR improvement but nothing impressive. Or atleast nothing I think should be far to impressive.
I fear in the worst case scenario, you'll need to replace your router. There are a few expensive models, but I suggest going with the more "premium options" as for they are more easy to setup/maintain and offer higher performance.
I hope this helps, please let me know if you need any more help.
Best Regards
Karan M.
Define "really slow" You have to remember that at any point in the connection between you and what ever you are trying to do can be throttled. You could have a "super duper 600Meg connection with your ISP and the hardware at home to match it but the source of the "download or data" could be the limiting factor. Plus if you are doing something like file sharing or torrenting  without using a VPN then yeah, your ISP is throttling your activity, as it is (cough) illegal. Wireless connections are notoriously slow and have extra lag time anyway. There is nothing like a good wired connection in comparison.
                  Did I help you to fix your problem or at least did offer somewhat valuable advice? Consider giving my post a "informative" or "thumbs up".
SYSTEM 2: Modded G3 case with Gigabyte GA-G33M-S2L, Intel E8600 (O.C to 4.2GHz.), 4GB GSkill PC8500, Nvidia 8800GTS (512M), Cooling provided by Scythe Big Shrunkin, HDD 1 = OSX 10.9.5, HDD 2 = Windows 7 Pro X64. (Placed 3rd in MacMod  of the year 2012) (For info see:  http://insanelymac.com/forum/topic/285641-and-the-winner-for-macmod-of-2012-is/
LAPTOP: Inspiron 1720, Modded BIOS, X9000 Core 2 extreme OC'ed and undervolted to 3.4GHz (windows only) , 6GB DDR2 800, 8600M GT, 1920x1200 Glossy display, Sigmatel Audio, 2 Kingston HyperX 120GB drives (1 with Windows 7 x64 pro & 1 with OSX 10.9.5) X9000 Processor World Record Holder since 02/2013 on Geekbench 2 : http://browser.primatelabs.com/geekbench2/search?dir=desc&q=x9000&sort=score
