Case Ideas!
Thanks for the help, It'll be on a H100i GTX On the stock clock speed. I just wanted something with plenty of Power & Cores.
The problem with "plenty of power" is the only "power" you're getting with a 9590 (or otherwise) is the power draw out of the wall racking up your electric bill.
That being said, a Xeon would be a much cheaper and stronger overall choice for a rig that would also be able to handle that 290X without bottlenecking it in the slightest, and showing its real advantages even more once you end up crossfiring those 290Xs. 4 cores, 8 threads, and all at the price of an i5 (you can't overclock, but you don't need to with a Xeon). @i_build_nanosuits and @Faceman will agree; a 9590 is not worth the cost. Even an 8320/8350 is a better choice (I am NOT recommending those as alternatives).
Gettign back on topic: The H440 is a brilliant case in red/black (though is a bit costly and suffers from slightly restricted airflow). I would never recommend this case for someone running a 9590 with Xfire 290Xs unless you've got a fully custom water loop system. Air cooling a system of those specs with turn your PC and room into a massive hotbox (with a liquid loop it'll just be your room). Something like a HAF series case from Cooler Master is a air cooling friendly option, but they suffer from the "transformery/lolz I is a gamerz" look. not to discourage them, they offer many great features. Just a heads up.
