So in two weeks i will be getting a Ethernet cable in my room
Danielh90
I will be running the Ethernet cable from my router to my room i have couple of computers i would like to have them plug in. So i had the idea of buying a switch and having the Ethernet cable plug in to that and just buy couple of of Ethernet cable to the computers will that work ?
Soon all of the p0rn will be yours!
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Yup, a 5-8 port unmanaged gigabit switch that's full duplex (99% are full duplex) will work perfect.
Mein Führer... I CAN WALK !!
k ? that has nothing to do what i asked but k
Whats a unmanaged gigabit switch sorry i am new to switch and stuff :)
yep. I have that too (I have a d-link 5 port gigabit switch. works like a champ
It's just a standard dumb switch, no setting to configure just plug in and play, the router does all the work automatically.
Witch would be  a good switch to look in to ?
Netgear, D-Link, TP-Link.
I have a netgear router would the netgear switch work best ? with it or does it not matter ?
It doesn't matter what brand you use. I'd suggest getting one that's at least 8 ports. 10/100/1000. I'd also suggest getting one based on what you need, but also taking into consideration what you might add later on, So don't go buy a 4 port switch, if you plan to add more computers, or add a server.
Please quote/tag ( Found by typing @DarrenP) In all posts directed at me. I do not check my current content.
Intel Core i7-4790K - Gigabyte Z97X-UD5H-BK - 16GB Corsair Vengeance Pro 1866Mhz - EVGA GTX 980 - 256GB MX100 - 2TB WD RED - 900D - H100I - Corsair HX1050 - DNS 320L 2x2TB Seagate Barracuda
Doesn't matter, but Netgear does have some pretty nice 5 or 8 port switches for $15-$25 USD.
Thank you :)
Here you go, you can buy this switch: http://www.amazon.com/NETGEAR-5-Port-Gigabit-Desktop-Switch/dp/B00QR6XFHQ/
TBH the five port switch is probably fine. If you ever do need more ports you can always go out and buy an 8 port one when you need it. Because they're damn cheap anyways. Odds are you'll still have somewhere to use the five port one especially if you're wiring up the whole house.
Fools think they know everything, experts know they know nothing
