Dark Rock Pro 3 vs H100i GTX in Corsair 300r
Solved by Enderman,
Do you have any specific (black) fan recommendations? My motherboard is also quite large. I have an Asus Sabertooth Z77. Will the radiator be thin enough and will the new fans be thin enough to still fit it?
Thanks for all of your help so far by the way. (:
the motherboard should be fine with 25mm fans
the noctua industrial fans are a bit loud but perform great
noiseblocker and bequiet make some good quiet fans too
if available, fractal design just released some very quiet radiator fans that are also black
