Will a i5-4690k bottleneck two 4K display?
Solved by costacis21,
you would benefit with a better cpu, because more expensive cpus tend to have more pci lanes available hence GPUs have higher bandwidth which will be beneficial if you are gaming on a high resolution. On the other hand, i believe that if you are gaming on a single 4k panel, you should be good with an i5.
Featured Topics
Louscou ·
Posted in Troubleshooting0 -
1
nulcow ·
Posted in Laptops and Pre-Built Systems2 -
2
1
SteffanF ·
Posted in New Builds and Planning3 -
2
HyperPalBuddy ·
Posted in Audio1 -
1
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
