Amd's most 'powerful' cpu is the fx 9590. Its just an overclocked 8350 in reality and in terms of performance its similar to intel's midrange core i5s. Intel's most powerful cpu is the 5960x. Its a beast with a price tag to prove it but If you are gaming at 4k I would get an i5 and call it a day. There is almost no difference in gaming between i5s and i7s. Certainly not enough difference to warrant the larger price tag (if you are gaming).
https://linustechtips.com/topic/332682-need-cpu-for-4k-gaming/#findComment-4515216
Currently there isn't a AMD Cpu which is equivalent to the 5820k.
indeed, the highest desktop amd processor is the FX-9590 @ 4.7 Ghz (it has 8 cores) with a 220W TDP (you need really good cooling) for 240$ so its the equivalent to the i5-4690k
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113347
i'd go with the i5 tho :D
https://linustechtips.com/topic/332682-need-cpu-for-4k-gaming/#findComment-4515221
Heya guys, i was wondering, what is the equivalent AMD cpu to the 5820K or in that range, also is intel overall better or AMD?? for 4K gaming that is :) not comparing prices but performance :D also whats the most powerful amd cpu??? i searched but its giving me different answers :3
You should just get a i5 4690k or if you want hyper threading get an i7 4790k, On the Z97 chipset, no need to go to X99 because X99 isn't good for games because of it's lower single threaded performance and lower (stock) clock speeds, X99 is made for professional content creators not gamers :)
https://linustechtips.com/topic/332682-need-cpu-for-4k-gaming/#findComment-4515228
The i5 doesn't come overclocked to its limits though, unlike the FX 9590.
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/332682-need-cpu-for-4k-gaming/#findComment-4515230
Per Core performance nothing is touching the i5-4690k all the way up the X99 i7's. Yes the AMD's overclock well but they are basically the same chips ( 8350's). If this is for gaming, you'll get similar results benchmarking these chips, but once you get into productivity, Intel blows it all away.
CPU: I5-4690K @ 4.3ghz | MOBO: Asus Z97-A | RAM: HyperX Fury 2x4GB White | GPU: Asus Strix GTX 970| SSD: Samsung 850 EVO 250GB | PSU: EVGA 750B2 80+Bronze |
https://linustechtips.com/topic/332682-need-cpu-for-4k-gaming/#findComment-4515233
The i5-4690k is an Unlocked chip & a fantastic overclocker. I personally have mine at 4.3ghz on air. Sure to go higher once I water cool.
https://linustechtips.com/topic/332682-need-cpu-for-4k-gaming/#findComment-4515241
I know, for me however its going to be an i5 4440 until I've saved up enough for an unlocked Haswell i7. (Which is made easier by the fact that my LGA775 rig will be more than capable when its Xeon X5450 is up and running again-meaning my LGA1150 mobo will last longer).
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/332682-need-cpu-for-4k-gaming/#findComment-4515245
i5-4440 will max out ANY gpu configuration at 4K.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/332682-need-cpu-for-4k-gaming/#findComment-4516855
Carefull with Intel hexacore** cpus, i've read something about intel versus amd at4k gaming and i was very impressed with the FX8350
here's the link : http://www.tweaktown.com/tweakipedia/56/amd-fx-8350-powering-gtx-780-sli-vs-gtx-980-sli-at-4k/index.html
The cpu tested (i7 4930) almost as fast as the 5820K for gaming.
If you wanted AMD cpu, i would say the FX-8350 is quite good for 4k.
**they are meant for work i guess not gaming*
https://linustechtips.com/topic/332682-need-cpu-for-4k-gaming/#findComment-4517891
JESUS, thanks for all the info guys, really helped, i am waiting for the R9 390x BUT i  MAY be inclined towards a single Titan...also assuming both cards are solo sufficient to pump 30-60 fps in 4K gaming, would a 4790K be enough??? i heard this card is not good for sli or crossfire cause it has less Pcie lanes?? *hope i dont sound dumb xD *
https://linustechtips.com/topic/332682-need-cpu-for-4k-gaming/#findComment-4571845
you could run a 4690k. i ran my 2550k for a while and the difference between that and my 2600K in 4k gaming was no more than 5fps.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/332682-need-cpu-for-4k-gaming/#findComment-4573029
