Poll on multi-monitor setup!
HeyKitty
Just curious what people use. I am mostly a media watcher or content creator, not really a gamer.
THIS IS MY SUPER TEENY TINY SIGNATURE!
Ain't it just the cutest little signature.
Some would argue it is the cutest little signature ever.
I use 3 monitors and I love it! I thought it wouldn't be a huge improvement over two, but I was way wrong
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
i use tripple and i curve them in not sure on angle but barly fits my old desk in storge atm with moving
Main Rig: CPU: 3570k Mobo: ga-z77x-ud5h-wb :RAM: 8gb kingson ddr3 1600 :gpu crossfire amd 290's Case: zalman z9 plus Cooler: h80i p/p SSD: nutron 120gb HDD: 2tb wd green 4tb seagate desktop
Girlfirends: CPU: 8350 Mobo 990fxa-ud3 Ram 8gb kingson ddr3 1600 gpu: his 7850 case: inwin dragon rider SSD: nutron 120gb HDD: 2tb seagate
Very slight curved on the two outer monitors
New PC Build - Build Log - http://linustechtips.com/main/topic/276039-project-swift-force/
[spoiler=]
  • Case: Phanteks Enthoo Primo
  • Motherboard: Asus Maximus VII Hero
  • CPU: Intel i7-4790K
  • GPU1: GIGABYTE G1 GAMING GTX 970 4GB
  • GPU2: GIGABYTE G1 GAMING GTX 970 4GB
  • RAM: Corsair Vengeance Pro Red, 16gb (2x8GB) @1600mhz
  • PSU: EVGA SuperNova 850W 80+ Gold
  • CPU Cooler: NZXT Kraken X61
  • HDD: Seagate Barracuda - 2TB 7200RPM
  • SSD: Samsung 840 EVO - 250GB
  • Monitor: Asus PG278Q ROG Swift 27" 144hz G-Sync
  • Headphones: Beyerdynamic DT990 Pro 600 OHM
  • DAC/AMP: Mayflower Objective2 + ODAC Combo
  • Mouse: ROCCAT Kone Pure Optical
  • Keyboard: KBP V60 - Cherry MX Brown
How are your monitors set up? I am thinking of going bezel-free and making it look more like one giant screen.
7680x1080 ftw. and side by side curved a little bit but not much
CPU: i9 19300k////GPU: RTX 4090////RAM: 64gb DDR5 5600mhz ////MOBO: Aorus z790 Elite////MONITORS: 3 LG 38" 3840x1600 WIDESCREEN MONITORS
Curved but I can't tell you the angle, I just put them where I feel like they should be
"The of and to a in is I that it for you was with on as have but be they"
Looks something like this http://3dvision-blog.com/wp-content/uploads/2011/04/3d-vision-surround-test-setup.jpg
But every single monitor I have is a different size. Sure it doesn't look super clean, but it works perfectly :)
Slightly curved, outer monitors cover the bezel of the middle monitor otherwise they wouldn't fit on my desk.
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
I think if you're gonna curve the monitors (which you should) you should have them on arms with VESA mounts so you can move them out of the way if you're working.
But if you're Linus and can dedicate a desk just to gaming then curved is best.
Dual Boot Windows & Hackintosh
CPU: Intel 4790K | Motherboard: ASUS Maximus Hero Vii | GPU: Zotac AMP! Extreme GTX 970 | Display: ASUS PB278Q | Case: Phantom 630 | PSU: Corsair HX1000i
Canada eh?
I use the curved monitor setup with my the two side monitors at a 25 degree angle. If I'm at my workstation I have 3 monitors but one on one desk each spread out among 3 desk so I have it all organized between coding, 3d animation and rendering, and whatever else I need.
i have my monitors at a very slight curve because the arm wont allow any more of a curve lol
l Intel Core i7 4790K @ 4.5Ghz l Asus VII Ranger ROG l MSI GTX 970 @ 1555MHz l
PC PART PICKER
