I Dun Goofed... How do I Reinstall Minecraft Jar?
For ease of mind, I'd suggest using MultiMC (or at the least MagicLauncher) if you're going to be playing anything other than Vanilla Minecraft.
Set up an instance (what MMC calls them) of the particular Minecraft version you wan (say, Release 1.7.10), launch it once to get the appropriate files, then mod away to your hearts content, knowing that you can turn mods on/off and have more than 1 version of Minecraft set up at any time without affecting the others or having to copy-paste them around when you want to swap - just double-click on the icon of an Instance and it'll run.
Feed-The-Beast (aka: FTB) Launcher is also a decent way to easily get pre-made modpacks that you can be sure if you've got a bug during gameplay, then someone else can replicate it and tell you how to fix it.
