I need help with my OS
Voidseeker
I have a USB drive with Windows 10 pro on it and I have a PC with a new SSD and the PC Is completely wiped and I go through the steps and it asks for a product key but I just want to get windows installed to make sure this works but every time I click skip. Now it installs it and the PC restarts which is normal but then it wants me to go through the whole process again.
Just now, whispous said:
After first reboot, take the USB drive out.
Alright I'll try that thanks.
Sounds like its set to boot from the usb,
After the install remove the USB and see if it boots to the SSD
Daily Drives
Windows 11 + Mac Soma + Mint Linux + Ubuntu MATE
HomeLab
Proxmox + OPNsense + TrueNAS + Zabbix + Debian + win Svr 2022 + win10 + Home Assistant + iventoy + plus other junk  and like 12 dockers!
Home Network
Unifi  - Express, flex, 8 port POE, Ap's other switches
Will do. Thanks
Will do. Thanks
Wooo! awesome!
Daily Drives
HomeLab
Home Network
