Replacing CPU Heatsink Fans?
@Archangel1994 The biggest problem is with Noctua (and that's a fact) is their bad color selection
. I have a windowed case, so I really want to stick with the R1.
And the fan types you suggested, are those compatible or just quiet?
Just about every 140mm fan should be compatible and they are all pretty quiet, I recommend you use good fan control on them though (Don't have them maxed all the time)
Also for that color suggestion I understand that
Featured Topics
tippytipper ·
Posted in Storage Devices0 -
2
AlyShazli ·
Posted in New Builds and Planning4 -
4
Emmanuel Katto ·
Posted in Peripherals3 -
2
2
Rusty Proto ·
5
WildOne ·
Posted in New Builds and Planning2
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
