How much vram do i actually need?
Go to solution Solved by Briggsy,
In cases where you are maxing your VRam, then System Memory will be used instead. PCI-E 3.0 can transfer 985MB/s per lane in one direction (so 15.39GB/s @ 16x), which means that faster system memory, up to 2133Mhz (which has ~17GB/s bandwidth in dual channel), should theoretically increase performance if you run out of Vram (which should be rare with current games).
In short, 3GB of Vram for a single 780 is going to serve you fine for years. there are even 6GB variants of the 780, which as silly as that seems, would be a great choice if you find a deal on one.
3GB should be enough.
Hey guys, i am looking for a gpu and i thought to get a gtx 780 and i saw that it has 3 GB of vram and my question is: is that enough? I'm playing at 1080p...
Thanks in advance
Currently: yeah.
Thanks in advance
As Minibois said, for now. Newer games are getting bigger and badder.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
3 or 4GB should be plenty
Current Rig:   CPU: AMD 1950X @4Ghz. Cooler: Enermax Liqtech TR4 360. Motherboard:Asus Zenith Extreme. RAM: 8GB Crucial DDR4 3666. GPU: Reference GTX 970  SSD: 250GB Samsung 970 EVO.  HDD: Seagate Barracuda 7200.14 2TB. Case: Phanteks Enthoo Pro. PSU: Corsair RM1000X. OS: Windows 10 Pro UEFI mode  (installed on SSD)
Peripherals:  Display: Acer XB272 1080p 240Hz G Sync Keyboard: Corsair K95 RGB Brown Mouse: Logitech G502 RGB Headhet: Roccat XTD 5.1 analogue
Daily Devices:Sony Xperia XZ1 Compact and 128GB iPad Pro
i have a gtx 780 3gb its a very powerful card but many games are capping the vram on it already...i fear for the future, i'd love to have 4 or even 6gb on it.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
Why not 970?
VRAM problem: can only use 3.5GB
These days, 4gb needs to be the new standard. Sure you can set the settings a bit lower an make do with 3gb of Vram, but if you want to turn everything up to max, you need 4.
Dubs are better than subs
I swear to god... people need to stop spreading bad information.
There is 4GB of usable VRAM on a 970.
As you said.
But only 3.5gb is running at advertised speeds, the last .5gb will slow you down significantly
CPU: I7 4790K(4.6@1.252v)                               Case: Fractal Design Define R5 Windowed(Black)           Cooler: CM 212 EVO + NF F12 iPPC
RAM: HyperX Fury 1600MHZ CL10 2x4GB      Storage: Samsung 850 EVO(250GB) + WD Red(2TB)      PSU: Corsair RM750 (and no, it hasn't blown up!)
MoBo: Asus Maximus VII Ranger                      Graphics: MSI GTX 970 TwinFrozr (1494MHZ Core)       OS: Windows 10 Enterprise
I haven't found a game yet that I can't run at max textures with two 2GB cards in SLI. As far as the other screen effects I turn depth of field, ambient occlusion, motion blur off in all cases regardless of performance cause I just don't / like care for them. (I hate blur and I certainly don't want blur at the expense of frames! AO is just not noticeable for me) I always fiddle with anti aliasing too. My library includes BF4, Crysis 3, Dying Light, and modded Skyrim. don't have Shadow of Mordor yet to try the vram killer most people link. That being said still aim for 3 GBs or higher but if your budget is in the mid range cards (R9 270(x), GTX 960) it isn't the end of the world.
Bugger all uses that much at 4K. Recommending the top tier cards just for 1080p is stupid.
It's also not "standard." It's on the 970, 980, 290 and 290X. They are not "standard" cards, they are the top end of what's available (other than Titans).
As you said.
There is a guy on here running 970 SLI at 4K and he hasn't had any issues with memory.
Like which game?
I'm not planning to change the card for at least 2 years, what should i do?
I'm not getting any amd cards because they are updating their line in Q2 but i can't wait til Q2 come on AMD can't you anticipate a little?
Why not 970?
The 980 is too expensive and the 780 is better than the 970!
I am really confused...
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
In cases where you are maxing your VRam, then System Memory will be used instead. PCI-E 3.0 can transfer 985MB/s per lane (so 15.39GB/s @ 16x), which means that faster system memory, up to 2133Mhz (which has ~17GB/s bandwidth in dual channel), should theoretically increase performance if you run out of Vram (which should be rare with current games).
PCIe 3.0 x16 can transfer 32GB/s.
https://www.pcisig.com/news_room/faqs/pcie3.0_faq/#EQ3
my bad, I should have added "per direction"
Well that is reassuring, thanks Briggsy!
I think i'm going with the 780 then!
