My Second Water Cooling Build in NZXT Switch 810
V1RK
Hey
I've just completed my second water cooling build this time I decided to change everything up since the last build I swapped the motherboard for a MSI z77 M-Power Big Bang and that system literally went off with a bang taking out everything other than the cpu and the hdd's and ssd's lucky. In this build the parts used are
  • Case- NZXT 810 Switch White
  • CPU- Intel 4820k x79 @3.9Ghz (Will be over clocking soon)
  • Fans- 2 Case fans and 5 Corsair SP120 LED white fans
  • Motherboard- Asus X79 Sabertooth
  • Memory- Kingston Hyper X beast 16GB 1600Mhz
  • Hard Drive 1- 2TB Seagate Barracuda
  • Hard Drive 2- 2TB Seagate Barracuda
  • Hard Drive 3- 3TB Toshiba
  • Solid State Drive 1- Kingston 240GB v3
  • Solid State Drive 2- Crucial 240Gb
  • Power Supply- Corsair AX860i
  • Graphics Card- EVGA GTX780 Hydro Copper Classified
  • Sound Card- Asrock Sound Blaster
WaterCooling Parts
  • WaterCooling Pump and Res- XSPC D5 Photon 270
  • WaterCooling Tubing- XPSC 3/8 ID - 5/8 OD 16/10mm Clear
  • WaterCooling Bits- XSPC G1/4 XPSC 3/8 ID - 5/8 OD Compression Fittings with 45 and 90 degree joins
  • WaterCooling Rads- XSPC Triple rad 120mm Crossflow & XSPC double 120mm radiator
  • Extras- XSPC Green watercooling temperature sensor & NZXT Hue
  • WaterCooling Dye- XSPC EC6 Blood Red
Monitors on Dual Stand clamped to desk
  • Asus VE278H
  • LG IPS-27EA63
Keyboard & Mouse
  • Corsair M65 Gaming Mouse
  • Razer Black Widow Ultimate (US layout)
post-15876-0-56123900-1423169550_thumb.j
post-15876-0-81249600-1423169566_thumb.j
post-15876-0-17699300-1423169586_thumb.j
post-15876-0-68960800-1423169604_thumb.j
CPU:Intel i7 2700k OC @4.9Ghz cooled by custom water loop with xpsc dual240 rads, xpsc block and 750 pump/res|Ram:G-Skill RipJaw X 32GB 1866Mhz|Case: Corsair 750D|Motherboard:Asus Sabertooth Z77| Hard drive: 240GB Kingston SSD, Seagate 2TB, 1TB Hitachi |GPU: EVGA GTX 770 SC cooled by custom water loop with xpsc gtx 770 block|PSU: Corsair HX750|Monitor: LG 27 inch IPS LED Cinema| Sound Card: Creative Fatal1ty X-FI professional| Build log:
https://linustechtips.com/main/topic/64792-just-finished-off-first-watercooled-rig/
-snip-
Looks good but my OCD goes crazy when I see those monitors.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
Not the only one, nice setup though
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
I use the Asus monitor mainly for CCTV which is connected via Cat 5 with VGA adapter down to dvr downstairs or for the xbox time to time. Gaming wise the LG is better
Yeah, seems to be weirs looking straight at the pole, plus the two different sizes. Then again i have 3 different sized monitors and its not as bad as you think.
@V1RK  Wont your head hurt always facing one way?
[Case Mod] Operation: The Division --- > Here
[CUSTOM WATER COOLED TABLE] Project: Ravage ---> Here
-== QUOTE ME IN YOUR REPLY IF YOU WANT ME TO RESPOND ==-
I broke the asus bracket pissed me off out of the box but the stand on vesa mount for asus is thicker since spacers is needed where as LG just mounts on to the plate. I didnt intend to use both for gaming or full display put together both separate displays. Not really face the middle you see fine plus they extend out so can move them around if needed.
