I would also suggest MSI MAG 341CQP, but curious what exactly you need HDMI 2.1 for. Newer monitors nowadays can support 1440p, 120hz & HDMI forum VRR on HDMI 2.0 port.
If you're more cautious of burn-in, then there is AOC AG344UXM which uses IPS panel instead with mini-led. I don't have either monitors though as I'm waiting for more 240Hz ultrawide monitors available.
PC spec:聽CPU: RYZEN 9 9950X3D | GPU:SAPPHIRE NITRO+ 7900XTX聽| MB:聽MSI MAG TOMAHAWK x870聽|聽RAM: G.SKILL TRIDENT Z NEO 64GB (2x32GB) DDR5-6000 30-40-40-96聽|聽COOLING:ARCTIC LIQUID FREEZER III 360, BE QUIET! SILENT WINGS 120 & 140mm| CASE:ANTEC C8聽|聽UPS: POWERSHIELD COMMANDER TOWER 1100VA
PERIPHERALS: KEYBOARD: CORSAIR K95 PLATINUM XT BROWN SWITCH | MOUSE: LOGITECH聽G502X PLUS WIRELESS聽| CONTROLLER: PDP AFTERGLOW WIRED CONTROLLER, DUALSENSE
DISPLAYS:聽GIGABYTE MO34WQC2聽|聽2x DELL S2721DGF |LG C1 48"
HT & audio stuff:聽 AVR: MARANTZ SR7013 | STEREO AMPLIFIER:聽YAMAHA AS-501 | SPEAKERS: DALI OBERON 7 & DALI ZENSOR 1 & 2x SVS-SB2000 | HEADPHONE DAC+AMP: TOPPING L30+E30 | HEADPHONE: SENNHEISER HD6XX, BOSE QUIETCOMFORT 35 II聽| MICROPHONE: AUDIO-TECHNICA AT9934USB | BLU-RAY PLAYER: PANASONIC UB820
https://linustechtips.com/topic/1569620-need-your-advice/#findComment-16405842
