5930K, but it's a bit overkill.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/303787-i-need-help/#findComment-4128860
Either of the i7s, preferably the 5820K unless you plan on going past 2-card SLI/CFX.
It's overkill though, just get an i5 unless you do content production.
https://linustechtips.com/topic/303787-i-need-help/#findComment-4128872
Hi, I need help picking a CPU out of these:
AMD FX 9590
Intel Core i7-5820K
Intel Core i7-5930K
Which is the best for gaming ?
i5 4690K.
Very very few games use more than 4 cores, and probably only 1-3 games use hyperthreading, meaning that an i5 is just as good as an i7 in games that don't use hyperthreading, and a quad core is just as good if not better than a 6 or 8 core processor. (Typically processors with more cores will end up having less powerful cores)
https://linustechtips.com/topic/303787-i-need-help/#findComment-4128876
AMD FX 9590
Intel Core i7-5820K
Intel Core i7-5930K
4690K is the best. 5820K/5930K are overkill and the 9590 is weaker than the 4690K.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/303787-i-need-help/#findComment-4128878
None, go with a 4690k or 4790k. The i7 5XXX's are way overkill for gaming. Unless if you plan on using your PC as a workstation, you will be spending a lot more money on not much more performance. Also the FX is a topic for another day, but for the games today it won't perform well.
Edit: What GPU(s) are you using?
https://linustechtips.com/topic/303787-i-need-help/#findComment-4128903
Going to get a Nvidia GTX 980
i5-4690k
i7-4790k
Hell if you wanted to save some money you could buy a second hand older i7
(i7-3770k i7-2600k-2700k)
Any of these will do nicely
Nvidia is to Dr Dre Beets as AMD is to KFC.
One makes you broke, the other you can get more of and have a midnight snack from the fridge when hungry again. Once you go Nvidia, you go broked, turn into an Elitist, or get the incorrect amount of VRAM.
- WCCFTECH
 I was only 9 years old. I loved Fifflaren so much, I had all the NiP merchandise and matches pirated. I prayed to Fifflaren every night before bed. Thanking him for the life I have been given. Fifflaren is love I say. Fifflaren is life. My dad hears and calls me a fuckhead. I knew he was just jelly of my passion for Fifflaren. I called him a Sw@yer. He hits me and sends me to go to sleep. I'm crying now, and my face hurts. I lay in bed and it's really cold. A warmth is moving towards me. I feel someone touching me. I feel someone touching me. It's Fifflaren. I am so happy. He whispers in my ear; "this is my pyjama". He grabs me with his powerful Swedish hands and puts me on my hands and knees. I'm ready. I spread my ass cheeks for Fifflaren. He penetrates my butt-hole. It hurts so much but I do it for Fifflaren. I can feel my butt tearing as my eyes start to water. I push against his force. I want to please Fifflaren. He roars a viking roar as he fills my butt with his love. My dad walks in. Fifflaren looks straight into his eyes and says; "He is a ninja now". Fifflaren is love, Fifflaren is life
https://linustechtips.com/topic/303787-i-need-help/#findComment-4129284
Unless you're doing content creation don't bother with X99 or X79 just pick up an i5 or i7 on Z97 and reinvest your savings into more gpu power for a better gaming experience.
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
https://linustechtips.com/topic/303787-i-need-help/#findComment-4130818
i5-4690K or i7-4790K depending on your budget...make sure you pick a Z97 board that support dual GPU's at x8/x8 if you plan on using dual graphics cards.
If you live near a micro-center store make sure you check their in-store only combo deals it's worth a drive they can save you almost 100$ when you pair a select Z97 board and i5 or i7 processor.
If you don't live close to a micro-center, you'll have to order online in which case with the prices right now (i7-4790K is 100$ more right now...not worth it IMHO :()
this is what i suggest for your gaming rig:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($219.75 @ OutletPC)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard ($100.98 @ Newegg)
Total: $320.73
Generated by PCPartPicker 2015-02-03 21:31 EST-0500
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/303787-i-need-help/#findComment-4130829
4690k if you want rock solid.
The intel CPU's you listed if you want rock solid for a LONG ASS TIME. (at least compared to the 4690k)
Dubs are better than subs
https://linustechtips.com/topic/303787-i-need-help/#findComment-4130849
What is your total budget for the whole PC?
Having problems with your fresh Windows 10 install? PM Me!
Windows 10- Want To Disable Telemetry, Disable Cortana, Disable Windows Updates? Look at my guide HERE
LTT Beginners Guide  | Community Standards | TN&R Posting Guidelines
https://linustechtips.com/topic/303787-i-need-help/#findComment-4130866
AMD FX 9590
Intel Core i7-5820K
Intel Core i7-5930K
what is you budget
where are you located
is this just for gaming?
do you need monitor, keyboard, mouse and OS?
you need to qoute the ppl or else we wont know you answered us
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/303787-i-need-help/#findComment-4130902
Your signature sums up all of the info I'm trying to get from this guy
https://linustechtips.com/topic/303787-i-need-help/#findComment-4130923
budget - £2000
located in England
mainly for gaming.
This is what i would build:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£173.94 @ Aria PC)
CPU Cooler: Phanteks PH-TC12DX_BK 68.5 CFM CPU Cooler  (£39.74 @ Scan.co.uk)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  (£95.96 @ Scan.co.uk)
Memory: Kingston Fury White Series 16GB (2 x 8GB) DDR3-1866 Memory  (£106.95 @ Amazon UK)
Storage: Kingston Fury 240GB 2.5" Solid State Drive  (£79.99 @ Amazon UK)
Video Card: PowerColor Radeon R9 290 4GB PCS+ Video Card  (£199.99 @ Amazon UK)
Case: Thermaltake Chaser A31 Snow White ATX Mid Tower Case  (£77.75 @ Amazon UK)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  (£88.16 @ Amazon UK)
Total: £862.48
Generated by PCPartPicker 2015-02-04 18:12 GMT+0000
All black and white sexyness!
https://linustechtips.com/topic/303787-i-need-help/#findComment-4135752
Total: £862.48
thank you so much, appreciate it a lot :)
https://linustechtips.com/topic/303787-i-need-help/#findComment-4136642
CPU, motherboard and PSU IMHO should go unchanged...you might want to piick a case you like better or a GTX 970 GPU for example if you feel it's better... :) do you like this build? what would you improve?
https://linustechtips.com/topic/303787-i-need-help/#findComment-4136896
Thanks I do like this build a lot, only thing i would change is the case to NZXT H440 Black/Blue (just cause my fav colour is blue) and change the graphics card to a 970 or 980. Might change the cpu to a i7 4790K
Thank you very much :)
https://linustechtips.com/topic/303787-i-need-help/#findComment-4141481
Indeed if you can afford the 4790K and a GTX 970 or 980 then by all means go for it you wont regret your choices.
Also there's PLENTY of good Z97 motherboard that are black and blue if you like this colour scheme better and EVGA GTX 970 and 980 have some blue on them and are usualy quite cheap.
What i suggested was just more ''budget friendly'' and probably better price/performance ratio overall...but sure a 4790K and a GTX 970 would perform better.
Good luck!
EDIT: you might like this one better...
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  (£257.94 @ Aria PC)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  (£89.20 @ Aria PC)
Motherboard: MSI Z97S SLI Plus ATX LGA1150 Motherboard  (£95.99 @ Amazon UK)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-1600 Memory  (£113.99 @ Amazon UK)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  (£77.99 @ Ebuyer)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£34.45 @ Aria PC)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card  (£274.99 @ Novatech)
Case: NZXT H440 (Blue/Black) ATX Mid Tower Case  (£84.99 @ Amazon UK)
Total: £1117.70
Generated by PCPartPicker 2015-02-05 12:53 GMT+0000
https://linustechtips.com/topic/303787-i-need-help/#findComment-4142272
