Hey guys,i am buying a new system with these specs:
CPU AMD FX6300 OR FX4300
GPU MSI R9 270 GDDR5
RAM 8GB HyperX Fury 1600MHz DDR3
PSU Corsair GS500 500W
MOBO MSI Gaming 970
So i was thinking of buying an FX6300 for mid-end gaming,some small editing/photoshopping/rendering stuff.I am not thinking of overclocking,heavy multitasking or going to some insane speeds,i just want a decent processor that i can use instead of my trash Intel Pentium D 3.4GHz,and i will not upgrade my PC in the future,this is my only chance,even with this small budget.
BUT,today i was searching on Ebay for a FX6300 that is as cheap as possible because i am on a VERY LIMITED budget. (13 and saving up all the money by myself),and i ran across a 70$ FX4300 that is on sale and has a great discount for a difference of the FX6300 which i can't find under 100$ with shipping.
30$ means a lot to me,but i just want to know is there a big difference between the two processors because i am thinking of the 4300 cuz my budget is low,and i think i don't need a any better CPU.
Thank you very much,a
Appreciate your help.
https://linustechtips.com/topic/300453-difference-between-fx4300-and-fx6300/
Basicly they have two FPU modules.
Except the 4300 has 2 cores in each module and the 6300 has 3 cores in each module.
Both have 4 integer cores of 6 integer cores.
TL:DR One is a "quadcore" quotation on and the other is a "six core"
Cheers.
Cheers.
ugh, no, youve no idea what youre talking about, FPU isnt a module, its a unit in a core
@op both are same architecture, made of modules, each containing two cores. the 4300 is a 2 module part, and the 6300 is a 3 module part. Neither of them is a great cpu, but the 6300 is better, compares about to an i3 on the intel side
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
If you are doing any photo video editing at all go for the 6300
 The Wannabe is no longer. Replaced by the Flotilla. If you replace every part of a computer is it still the same computer?
Survived the Survivor 2299
Audio Engineer, Lighting Programmer, Video Engineer, FOH.
It was 3 modules i was wrong .
fx 6300 has 3 blocks that amd calls 'modules'. each module has 2 integer clusters and a shared 256bit fpu and some other resources. the module can execute 2 threads simultenously. a 3 module cpu can thus execute 6 threads. amd markets them as 6 cores mostly because of the integer clusters. the operating system seems them as 6 core cpus.
if you want further info on how modules and cores work, check out toms bulldozer review.
http://www.tomshardware.com/reviews/fx-8150-zambezi-bul...
So should i go with the 4300 because as i said i am not looking for some high performances
the 4300 is about the same as a gen1 core i5. so youre effectively buying into a 5 year old cpu. if you go for a 4core, go FM2+ with a 860k
Practically 10% is editing,everything else is gaming.
I just want to know is the 4300 too worse than the 6300
I meant they share the 256 bit FPU unit , go read the post where i corrected that.
Cheers.
Cheers.
That is true. One module shares most of the backend and the FPU
Yeah i got that a bit wrong.
Thanks for correcting me.
I appreciate it.
Its a complex arquitecture not easy to explain that well.
Okay,now i just want to know is 4300 too much of a bottleneck against the FX6300
No, No its not
neither 4300 or 6300 will bottleneck your graphics card if you don't intend to upgrade.
and for slightly higher performance ( though negligible) you can buy 6300 if you do light photo or video editing
otherwise you can switch sides to intel
Cheers.
4/6 Pipelines
4/6 Integer units
2/3 Front Ends (L1, Fetch, Decode)
2/3 FlexFPUs
both are a lot worse than a core i3 when it comes to gaming and they have no upgrade path...you should go with a core i3 and a cheap H series chipset motherboard instead...that way you could upgrade to an i5 or an i7 if you need more performance in the future...AM3+ is an old and dead socket with poor CPU when it comes to gaming.
If the core i3 is out of budget i'd suggest you look at an A88 chipset motherboard (FM2+) and an athlon 860K processor.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
Go for a 6300 or 860k
R9 270 will have bottlenecks from fx4300
“It would seem that Our Lord finds our desires not too strong, but too weak. We are half-hearted creatures, fooling about with drink and sex and ambition when infinite joy is offered us, like an ignorant child who wants to go on making mud pies in a slum because he cannot imagine what is meant by the offer of a holiday at the sea. We are far too easily pleased.”
―  C.S. Lewis  :)
Many games the FX4 performs very similarly to the FX6, so how will a R9 270 blanket bottleneck with a FX4 but not FX6?
http://linustechtips.com/main/topic/285927-gaming-performance-between-4300-8350-and-4-threaded-performance-between-amd-intel/
RIP in pepperonis m8s
That two cores and higher clock will benefit alot on bf4 espescially...
Id rather he go i3 tho
Amd cpu is just too old =(
Maybe he will play cpu heavy games?
―  C.S. Lewis  :)
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor  ($105.75 @ OutletPC)
Motherboard: Asus H81M-D PLUS Micro ATX LGA1150 Motherboard  ($40.98 @ Newegg)
Total: $146.73
Generated by PCPartPicker 2015-01-30 08:58 EST-0500
This is the best option any time of the week.
I think for purely gaming purposes, I'd generally say try with the 4300, but since the 6300 isn't much more expensive, and you can just OC it to the stock speed of the 4300, you might as well get the 6300 and OC it. If you look at the link FX4300 and FX6300, they are nearly identical in single-threaded performance, but the 6 core will obviously have more available threads than the 4-core. The slight speed difference between the cores 3.5 vs. 3.8 will make no difference. In a programming environment, more threads means faster compile times, much more so than higher speed cores. SSD's make a huge difference to the speed of a system.
