fan in bottom of case (for Linus)
enRodjavel
I've been using a bottom fan in my case since I built up my computer. It actually drops the GPU temperature a couple degrees because of the fresh air it gets.
For those who are going to put a fan in the bottom: get a dust filter! All the dust that collects on the floor/desk gets sucked into it.
I have a very similar setup: http://i.imgur.com/JNvhl8qh.jpg
i used to do it, but it A LOT (really mean A LOT) of dust enters through the bottom so i decided to remove the ventilation from there, but nowadays it's very easy to clean the fan filters (that is if you have a decent/modern case) so i would probably try it again...
I have a 140 in the bottom of my R4, helps the GPU by a few degrees
| AMD Phenom II X6 1100T 4.0 GHz, 16GB DDR3 (8GB x3) 1600, XFX R7950 800 MHz, 1TB 7400 64MB , Windows 7 Ultimate (64 bit), Fractal Design Define R4 |
| This user is located in - ~northern England, United Kingdom, Sol 3 |
When i used a 250 as a physX card, that thing was hotter than haswell (if you can believe that) so the bottom fan was dropping the temp from 90c to 80c, just a sickleflow. Luckily, my case has a huge filter from the psu till that spot, so i was getting no dust.
Codename: HighFlyer, specs:  CPU: i5 2500k cooled by a H70ish(2 rad)   Mobo: MSI MPower Z77   GPUs: Gigabyte GTX 660 OC 1150 MHZ core, 3150 memory both   RAM: Corsair Vengeance 16G @1600mhz   SSD: ADATA Premier Pro sx900 / HDD Seagate Barracuda 1TB/Samsung 1TB   Power supply: Corsair RM650 80+ Gold   Case Corsair Carbide 500R   5.4 ghz achieved on the good old 2500k, may it rest in peace. Current daily OC is 4.8 @1.41 v
Yeah I was surprised when Linus said that. I don't understand why not many people use it. That particular spot blows air air directly onto the GPU cooler intake. And wouldnlt really rely on much air passing through those drive cages.
I dropped a 120mm in as soon as I realized it was there.
“Snorting instant coffee is the best,” said Kayla Johns, 19, of Portland.
I also use mine, it's brings in tons of fresh air.
Come and join the awesome Official LTT Star Citizen Org at LTT Conglomerat,  GTA 5 LTT Crew at LTT Conglomarate
PC Specs - 4770k - OC 4.5GHz  - GTX 780 SC - 16GB HyperX - NZXT H440 White - Corsair H100i - Corsair AX750 - Samsung Evo 250GB - 2 x PA238Q - ATH-M50 -
I never used a bottom fan, even though my case has a filter.
And ever since i helped my friend with cleaning his PC, i am pretty sure that i will never use one in the future too.
Too much dust, at least at my location, more noise and all that, for the shake of 4-6 degrees lower temps.
Intel Core i7-3930K | Gigabyte GA-X79-UD5 | Corsair Hydro Series H100i | G.Skill Ares 64GB | MSI GTX760 TF 2GD5/OC | Creative SoundBlaster Z | OCZ Vector SSD 128GB | WD CaviarBlack 640GB | WD RED 2TB | Coolermaster Silent Pro M600 | Coolermaster 690 Pure Black Edition Case | Triple Monitor: Dell Ultrasharp U2311H - 2 x Dell Ultrasharp U2312HM
Synology DS918+ (4 x 4TB WD RED, Kingston HyperX Impact 16GB, 2 x Samsung 970 Evo NVMe 250GB)
MacBook Pro (Retina 13-inch / 16GB Ram)
iPhone X 64GB Space Grey
I use mine with an AF 120. pwnage
Super OP AF Killer Retro Emulation PC 360 No Scope 420 Blaze It (Sorry I Couldn't Help It) Seriously Though This PC Is Overkill And Before You Ask It Does Play Crysis 1024x768 60 FPS
Intel Core Duo 2 Quad Q9550 @ 2.83GHz // ASUS P5N-D // Zalman CNPS9500A Air Cooler // 4GB G.Skill @ 400MHz 5 5 5 31 23 // 2 Way SLI GeForce 9800 GTX+ // 32" SONY WEGA CRT TV 480i // Corsair TX750 // Seagate 3TB // Win XP 32Bit // Sony DVD RW // ANTEC Full Tower // Steel Series H Wireless // Logitech K520 Wireless Keyboard // Logitech M510 Wireless Mouse // Logitech G27 Racing Wheel // Thrustmaster T-Flight HOTAS // HORI Fight Stick Mini // 8Bitdo NES30 Pro / FC30 Pro / SNES30 / SFC30 Bluetooth Controllers
Future Upgrades The New 8Bitdo Wireless SNES Controller With Analog Sticks / 8Bitdo Bluetooth Arcade Fight Stick / Proper HD I Know This Machine Does Not Support 3 TB / Icy Dock 5.25 4 Bay HD Hot Swap Bay For More Seamless Multi Booting Want To Run At Least Win 95, Win XP, Win 7
i7 3770k @ 4.5Ghz // ASUS Maximus V Formula // CM Hyper 212 EVO // 16GB G.Skill Sniper @ 2133MHz 9 11 10 28 // Crossfire Sapphire 7970 // 42" 4K 60Hz FreeSync WasabiMango IPS // Corsair AX860 // Samsung 1TB 840EVO // Seagate 3TB // Seagate Barracuda 160GB sata II // OCZ Vertex 3 90GB sata III // Win 10 64Bit // ASUS DVD RW // 2 Corsair AF 120 // 2 Corsair SP 120 // 2 xigmatek 120 // Corsair 760t white flavor // NZXT HUE+ RGB Controller // Sennheiser G4me Zero // Steel Series H // Corsair M95 // Corsair K95 // 3 Xbox 360 Controllers // Dolphin Bar // Wii U Mote // Leap Motion Plus // Logitech G27 Racing Wheel // Thrustmaster T-Flight HOTAS // HORI Fight Stick Mini // 8Bitdo NES30 Pro / FC30 Pro / SNES30 / SFC30 Bluetooth Controllers
Future Upgrades 1080Ti or Vega RX64 http://linustechtips.com/main/topic/16900-nothing-special/
Bitfenix spectre pro in the bottom of my level 10 gt
GPU: Gigabyte HD7970 | Mobo: ASUS Z97i PLUS | CPU: 4790K
HDD: Samsung 1tb SSD | Disp: 3x Asus 23.6" 1080p
RAM: 16gb Kingston Hyper X | Case: None
idea... get the silverstone magnetic fan filter. i got one just for fun while i was browsing around hong kong. good if your case has a bottom mount with no filter. i dont have a fan mounted there atm since im getting sufficient cooling with a locked cpu and a poorly overclocked gpu :P i dont actually really need the magnetic fan filter since my case comes with one (bitfenix shinobi).
PC Specs:
CPU: Intel Core i7-4770K (Stock Speed)  Motherboard: Asus Z97 Sabertooth Mark-S  Memory: 4x8GB Klevv GENUINE DDR3 1600MHz GPU: EVGA GTX 550Ti PSU: Corsair RM850
I had one in the bottom of my R2 case.. :)
(Comming soon)
Since i got a FT02 I got 3 180mm AP fans on the bottom of mine  :lol:
I got 2 intake fans in the front, but since i have a Bitfenix Shinobi (with the hd cages pointing inside) i don't really think that would change much wih one in the bottom.
My case doesn't have a built in fan filter on the bottom so i need to buy one separately to use a fan there. But otherwise , why not if your case is on a desk and it's got lot of room below it.
Only bottom mouted fan i use is the PSU one so it doesn't count, I do have a spare 140mm fan that used to be in the back of my CoolerMaster Storm Trooper case. But i don't want a fan at the bottom, it's just that simple. But i guess the mount is for people who uses it so good on those who use it and hope it works fine for you aswell
I use my bottum mountend fan to.
I have a cooler master atcs 840 with al the fans mounted.
10 fans total (with cpu cooler noctua nh-d14)
I don't, no room for one really, and in my next case, there's no fan mounting on the bottom anyway... just hdd mounts... strange
Inside: 3570k@4.2, H100i with  NF-F12 Fans, AX760, GTX660 Z77 MPower,
Outside: Corsair 500R, M95, G15v1, Solo7C speakers.
I plan to have a raqdiator in the bottom of my casence I get my custom loop if that counts.
AMD FX8320 @3.5ghz |  Gigabyte 990FXA-UD3  |  Corsair Vengeance 8gb 1600mhz  |  Hyper 412s  |  Gigabyte windforceR9 290  |  BeQuiet! 630w  |  Asus Xonar DGX  |  CoolerMast HAF 912+  |  Samsung 840 120gb
2 WD red 1tb RAID0  |  WD green 2tb(external, backup)  |  Asus VG278He  |  LG Flatron E2240  |  CMstorm Quickfire TK MXbrown  |  Sharkoon Fireglider  |  Audio Technica ATH700X
#KILLEDMYWIFE
I have an nzxt 410 i dont use a bottom fan mainly because i have terrible cable management. My psu is non modular though so i find it difficult to fit it in :P
Guest
