LGA 1155 stock cooler running at 500 rpm
Solved by BuntzenB,
Apologies, i think the way i've written this has misled you a little. Alll this was done during installation. I haven't even taken off the side panels since i booted and encountered this problem.
Ah. i would recomend checking which header ur fan is plugged into
Featured Topics
Triggeravus ·
Posted in Graphics Cards1 -
Aden101 ·
Posted in Laptops and Pre-Built Systems1 -
JordanTrace ·
Posted in Audio3 -
systemdonut ·
Posted in New Builds and Planning2 -
awdasdwasdfgeasdf ·
Posted in New Builds and Planning3 -
4
3
12
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
