help with eyes and 120hz
haloharry97
I just need a little help, am having problems with my eyes, my eyes start to hurt when i play just a few lv when i play games like Rayman Legends or BIT.TRIP presents... runner 2, i was wondering if i get a 120hz or even 144hz with g-sync monitor if it woud help with my eyes, dose anyone know if it would help before spending my money.
Have you considered getting speciality glasses for use with monitors? 60Hz is unlikely to hurt your eyes, it's more likely just the strain of using monitors in general.
Its probably that your eyes are strained from looking at your monitor, it happens if you look at it for too long. If it really bugs you I guess you could get gunnar glasses.
edit: ninja'd
Maybe just staying a bit further from the screen could help... Also depends on the framerate u r actually getting... I think that my eyes are pretty hard to be satisfied, and is very rare that i actually see the 60fps as a limit... Also getting pauses every hour or half-hour and looking at a far point relaxes the eyes
rig: i7 4770k @4.1Ghz (delidded), Corsair Vengeance 8GB 1600Mhz, ROG Maximus VI Hero, Noctua NH-D14, EVGA GTX980SC, Samsung 850 EVO 500GB, Corsair SF600, self-built wooden Case, CoolerMaster QuickFire TK, Logitech G502, Blue Yeti, BenQ GW2760HS
I don't think hertz on a screen would make your eyes hurt or not. You should go to the doctor and maybe try glasses.
Rig: I5-3570K@4.3Ghz - Cooler Thermaltake Frio Advanced - Ram Kingston 1333Mhz 8gb (2x4) - GPU GTX 970 4GD5T OC - Motherboard Z77MA-G45 - PSU CoolerMaster GX II 750w - Storage WD 500gb HDD - Sound Edifier M3700 5.1 - Headset Corsair Vengeance 1500 - Mouse Razer Deathadder 2013 - Keyboard Razer Anansi - Mousepad Steelseries QcK+ - Xbox 360 Wireless Controller x2
I use some steelseries scopes (made by gunnars) really help my eyes during long days at work or at home infront of the PC
if its more serious, its possible you need glasses as your eyes could be straining to read
Try wearing sunglasses, if that eases your issues then, well, gunnars.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
May want to have a look at Benq's monitors:
http://benq.eu/eye-care-monitors/ff.html
Not sure if any tests have been done to prove that they work, but page should have information, also Gunnars Optiks may help you.
"Use the force Harry"
                   -Gandalf
the fact that they call them "gaming glasses" <<<<<
Really need to rename them as a marketing strategy.
                   -Gandalf
exactly :P personally ive never had an issue with the screen, although recently (like 2 months ago) i got glasses for far sightedness.
:P you're lucky, I get splitting headaches if i stare to long.
                   -Gandalf
