How Do I Ship A CPU with Box?
CowsGoRoar
If I'm selling my 4770K in retail box, how do I do that? Do I just put it in like normal and hand it over to the shipping place, and then they wrap it up and take care of everything? I've never been to one so if you could tell me how I can ship it, that would be great.
You put it in the original box with the stock heatsink and instruction manual.
I would bubble wrap the cpu in this  and then ship it on the factory box.
Motherboard - Gigabyte P67A-UD5 Processor - Intel Core i7-2600K RAM - G.Skill Ripjaws @1600 8GB Graphics Cards  - MSI and EVGA GeForce GTX 580 SLI PSU - Cooler Master Silent Pro 1,000w SSD - OCZ Vertex 3 120GB x2 HDD - WD Caviar Black 1TB Case - Corsair Obsidian 600D Audio - Asus Xonar DG
   Hail Sithis!
I said retail box so is that it?
Theres a little plastic tray/holder the CPU came in, put the CPU in that, then put the plastic with the CPU in it in the blue Intel box, along with the stock cooler
"Rawr XD"
No padding like @beebskadoo suggested? Are you sure it won't damage anything on its own?
Yes, the box you bought it in. It has a plastic tray for the stock heatsink and a small plastic box where the CPU goes in.
This is why you keep all the original packaging to your products.
@Enderman
You are assuming I don't have the packaging and etc.
I just said if it was okay it back into the retail box, meaning the blue box.
I meant if I had to put padding and extra protection like what beebskadoo said.
What don't you understand?
No, it's not an AMD chip. You don't need padding or anything. You could stomp on it and nothing will get damaged.
"Rawr XD"
Thanks. @Aniallation So it will look as if it was never used. Plastic cover on, manuals all inside, the sticker isn't even used, all in the retail box, and I can just ship it on its own. It won't roll around in the truck and crush the heatsink?
@Enderman
No it needs to be exactly how you received it, with the small plastic CPU box, no other padding or anything.
Did it come with a stock cooler? Just package it back in the box in reverse order of how it came
"Rawr XD"
Yes. It looks just like in the video.
Then just put everything back in in reverse order in which it's unboxed
"Rawr XD"
Yeah I get it already.
Also once you do that, put it into another, bigger box with padding
Intel 4670K /w TT water 2.0 performer, GTX 1070FE, Gigabyte Z87X-DH3, Corsair HX750, 16GB Mushkin 1333mhz, Fractal R4 Windowed, Varmilo mint TKL, Logitech m310, HP Pavilion 23bw, Logitech 2.1 Speakers
