[Build log(sorta)]The replacement for a prebuilt - Part 2
Speedbird
Hi
Now this post is LONG overdue. I mean, most of the pics you see here are from the 15th of September. But anyway, here it is.
Background:
Now, about a month ago I posted a build log on KAVERI-PC, the replacement for a prebuilt desktop (check it out at http://linustechtips.com/main/topic/210198-build-log-the-kaveri-pc-replacement-for-a-prebuilt/ ). But you probably didn't know that I had 2 prebuilt desktops. Also I found my dad's old PC a few months ago, and wanted to do something with that. I decided to switch completely to AMD, by getting rid of the other prebuilt and ptting some new hardware in an old case. So let's begin.
Tearing down the prebuilts:
Right then. Let's start off with the motherboard.
post-87518-0-16002400-1412524321_thumb.j
An H57 mATX board, made by ECS. Not that bad, actually. At least it's not Biostar.
Now the CPU, an i3 550
post-87518-0-42732200-1412524417_thumb.j
post-87518-0-20400100-1412524436_thumb.j
A Nehalem-based CPU, using 2 HT-enabled 32 nm Westmemere cores, running at 3.2 GHz.
post-87518-0-96576300-1412525056_thumb.j
The case, with the motherboard removed.
post-87518-0-07481100-1412525118_thumb.j
An optical drive, and an HDD hotswap bay.
The GPU originally used in here: a GT330 with 2GB of DDR3 VRAM.
post-87518-0-78041600-1412525178_thumb.j
post-87518-0-06481000-1412525391_thumb.j
An SLI connector?! I have another one too, maybe I should do something.....
The old PSU: a Delta 300W.
post-87518-0-09428900-1412525473_thumb.j
And the new PSU: a CX430M.
post-87518-0-38835800-1412525509_thumb.j
This is the CPU cooler. I see no point in this, they could've just used the Intel stock cooler.
post-87518-0-85213800-1412525571_thumb.j
You probably noticed the screws now. And now you're sure that it had a backplate. How does it attach? Very simple.
post-87518-0-00152300-1412525680_thumb.j
Tape. Double-sided tape. Yup, that's how it was. Nope, it has never come off.
Finally, the IO shield, which looks a lot better than most ones.
post-87518-0-26034000-1412525777_thumb.j
I don't really have much from this one.
post-87518-0-98226300-1412525857_thumb.j
The CPU cooler, installed on the CPU. Barely fits into the case.
post-87518-0-40557100-1412525939_thumb.j
The drive cage, with a WD Blue inside.
And finally the power supply.
post-87518-0-02735700-1412525991_thumb.j
LTT's unofficial Windows activation expert.
The PENTIUM-PC, now SEMPRON-PC
These shots were taken before I got the new motherboard.
post-87518-0-61975800-1412526214_thumb.j
In here, I had already replaced the PSU and the hard drive. The PSU is a Seasonic S12II-430BG. Pretty good, if it was modular.
post-87518-0-90689500-1412526291_thumb.j
Here's some Hitachi 1 TB drive I got from PC number 2.
post-87518-0-97542600-1412526329_thumb.j
2 Optical drives, one IDE, the other SATA.
post-87518-0-00336300-1412526390_thumb.j
Ah, the stuff you get with a case from 2004. Yes, this is front USB.
post-87518-0-56095900-1412526438_thumb.j
What the... I can't even... THIS IS NOT HOW CABLE MANAGEMENT WORKS!
post-87518-0-84843900-1412526476_thumb.j
SEMPRON-PC, again.
post-87518-0-10946000-1412526590_thumb.j
This is the case with the side panel closed.
post-87518-0-58706400-1412526626_thumb.j
And with the side panel open! (sorry for the poor lighting, this camera has no flash)
post-87518-0-73400200-1412526679_thumb.j
Hope you can see that it's a Gigabyte GT630...
post-87518-0-59090200-1412526735_thumb.j
The IDE ODD is not connected. The PCI Host adapter blocked the GPU fan, and it didn't work anyway.
post-87518-0-78192200-1412526799_thumb.j
I decided to put my WD Blue (bottom) here instead, the Hitachi one had some problems. Also put my Green (top) here, because I needed to see if it was working.
and that's it. Thanks for reading!
/Woulda gone with intel
/Rage at me
Was the cheapest CPU I found....
sorry, no vacancies
