D5 PWM or Vario?
Solved by ForsakenLive,
Temps don't change that much with pump speed (also it depends on the loop), but usually it's easier to get the vario, adjust the setting and forget about it.
vortexx21 ·
Posted in Power Supplies2 -
Hellowpplz ·
Atheos ·
Posted in Peripherals0 -
8
johnny45 ·
Posted in Linux, macOS and Everything Not-Windows0 -
DJpanda808 ·
Posted in Displays2 -
JakubR8 ·
Posted in Power Supplies8 -
AccordingOne ·
Posted in New Builds and Planning7
