[Buildlog] Project "Toxic Lizard" (5960X / 3-Way-980 / Watercooled)
Kukielka
Introduction:
Hello there fellow builders and modders!
This will be my new Buildlog for a new overkill machine.
I'm building this rig for https://www.youtube.com/user/ungespielt
Please see my other Buildlog here :)
Watercooling tubing will be sleeved also, I'll make a tutorial for that too (In the tutorial section).
ALL cables will be custom made!
Partlist:
CPU: Intel Core i7-5960X
Mobo: MSI X99S XPower AC
RAM: 8x8gb Corsair Vengeance LPX Black
PSU: Corsair AX1500i (with Bitfenix extensions...sorry, dont have much time to spend on sleeving :/)
GPUs: 3x GTX 980
WC: All EKs Flagship products (CPU 2011 Elite Evo, GPUs Fullnickel + Acetal), Tubing will be most likely Tygon, Rads: HardwareLabs Nemesis GTX series
Case: Corsair 900D
Fans: 17x Noctua industrialPPC 120mm PWM
SSD: 2x Samsung 850 Pro 256gb (Raid 0)
HDD: 8TB Seagate Archive
Sound: Asus Xonar Essence STX II
Complete Partlist! (German)
Make sure to comment your thoughts, I'm interessted in what you guys think :D
My Rig "Jenova" Ryzen 7 3900X with EK Supremacy Elite, RTX3090 with EK Fullcover Acetal + Nickel & EK Backplate, Corsair AX1200i (sleeved), ASUS X570-E, 4x 8gb Corsair Vengeance Pro RGB 3800MHz 16CL, 500gb Samsung 980 Pro, Raijintek Paean
:o
|| MAELSTROM ||
|| i5 3570K W/ CM 212x @ 4GHz || r9 290 Windforce || Corsair Obsidian 450D || 2tb HDD + 120gb 840 evo SSD || 2x4gb Hyperx Fury Blue
I've wanted something like this. But after thinking about it, a 4790k and 780 ti sli would work just aswell for me. Only if I have the money
Followed!
I just ordered my Rampage V Extreme and Corsair RAM and two 850 pro SSDs, hopefully getting 5960X in a few weeks.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
Because of the cool factor.
Well thats not a reason to waste 700$
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
Well, judging from the stuff he's going to use/get I don't think he's going for senseable choices but rather "because he can"
If I had the money, then I'd go for a 4 way SLI/XFire as well.
phanteks enthoo pro | intel i5 4690k | noctua nh-d14 | msi z97 gaming 5 | 16gb crucial ballistix tactical | msi gtx970 4G OC  | adata sp900
For some people it is. I would never, but i can not judge what people use their money on.
niether can i. but if you find a use for the 4th one thats fine. Just a wow factor from like a dozen people you've never met before isn't really worth 700$ imo.
Fair enough. :)
I would personally go with 2 dual cards, pcie ssd and raid card.
REMEMBER TO QUOTE SO I GET A NOTIFCATION! Add me on Steam: http://steamcommunity.com/id/Shroomster/ Review(s) more to come
i'd totally think 2 titans Z's would be like sick.
OT: what monitors are you running with these cards? like i think 8gb's is enough for 4k surround. 6gb's wasn't enough for 4 titans and it crashed some games at 4k surround.
Why not just 3 way? 4 way has like no scaling over 3way.
Overkill is what I want, it just pleases me to see every expansion slot occupied.
I also want to get into the top 20 of Firestrike Extreme with "only watercooling" :D
this will be interesting if not a little oversightful, you gonna get that white ASUS mobo?
Nope, X99S XPower is decided, I love the black and yellow theme :)
Followed!
Nice, pm me if you have a buildlog :)
^This.
^This.
I had a similar idea, but with the white Asus board though and 2 gpu. But I changed my mind and decided to do case mod for my old z77 itx pc and try my luck for an Ares 3.
Good luck then, they are hard to come by :D
If you dont find one, just get a R9 295X2 with EK Fullcover Waterblock, they are basicly the same :)
ooh, a nice yellow themed build. Subbed.
Thanks! :) You wont regret it!
Followed!
:-O
Hardware: Intel I7 4790K 4Ghz | Asus Maximus VII Hero Z97 | Gigabyte 780 Windforce OC | Noctua NH-U12P SE2 | Sandisk Extreme Pro 480GB | Seagate 500Gb 7200Rpm | Phanteks Enthoo Luxe | EVGA Supernova G2 850W | Noctua NF12 | SupremeFX 2014 | Patriot Viper 3 16GB.
Gaming Gear: Cooler Master TK Stealth | Sennheiser PC350SE | Steelseries Rival | LG IPS23L-BN ' 5ms | Philips Brillians 144hz
F--K YEAH, YELLOW.  :wub:
Oh, you...
If i tell you i have a yellow accent in my build, will you love me? :)
Specs: 4790k | Asus Z-97 Pro Wifi | MX100 512GB SSD | NZXT H440 Plastidipped Black | Dark Rock 3 CPU Cooler | MSI 290x Lightning | EVGA 850 G2 | 3x Noctua Industrial NF-F12's
Bought a powermac G5, expect a mod log sometime in 2015
Corsair is overrated, and Anime is ruined by the people who watch it
I'll need for information about said build.  :mellow:
Eh, it's not really noteworthy. I can't snag any good pics of it now, lightning isn't good at all.
All it is is a black on black on black build with a 290x lightning in it :P
