Be Quiet Silent Wings 2 vs Pure Wings 2
Solved by FizzyFantom,
I cut together their "general specs" so you can easily compare them:
If you are planning to use them on a radiator then you should go for Shadow Wings, they have higher static pressure. I have a 140mm Shadow Wings fan and it's quiet.
The Silent Wings are quieter and have higher airflow, but they have less static pressure than Pure Wings.
Edit: Fixed the comparison (from mixed sizes to all 120mm fans).
Featured Topics
Emilerk ·
Posted in Troubleshooting0 -
3
peacenattress ·
Posted in Graphics Cards3 -
Oxphos ·
Posted in Troubleshooting4 -
em_lab ·
Posted in Power Supplies3 -
