Coil Whine question
Go to solution Solved by Hinjima,
1 hour ago, em_lab said:
well i already had a 2016 build with this PSU. Last year i upgrade the PC ,new case + mobo+cpu +gpu 3090 but i kept the PSU and i was forced to use others cables that came from a RM550 much older and another RM850 newer due to that i dont think that i was not neccesay to buy a new PSU
If your GPU is having coilwhine then there isn't anything you can do about it.  Coilwhine is not dangerous or harmful in any way and does not affect the lifespan of the product.  Coilwhine is safe but it is annoying.
Hi i recently discover a Coil Whine effect in my PC, i didn't knew such thing exist
It happend when i start unreal engine in my PC then i heard a zzz zzzz zzzzz sound
that came from somewhere between the CPU zone and the PSU, i can not tell exactly
then i discover that when Unreal is actifs the power consumption of the GPU goes up to +350W
My PSU is a Corsair RM850x plus gold, so a 850w PSU  (8 years old)
My GPU is a MSI Suprim X rtx3090
When i mounted this build i used PSU cables form others PSU i had
I would like to ask you if this is bad or not, or if i must change my PSU or the cables
thanks in advance
https://linustechtips.com/topic/1569202-coil-whine-question/
If you can live with the noise, you don't have to do anything.
Coil whine is caused by resonating inductors that produce an audible noise, as far as I know it's not harmful.
English is not my first language, so please excuse any confusion or misunderstandings on my end, also I like to edit my posts a lot.
F@H-Stats
The Rigs:
Xenon:
CPU: 2x Xeon E5 2690 V3
RAM: 64GB DDR4 2133 RDIMM
MoBo: Supermicro X10DRi-T4+
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
RAM: 48GB DDR4 3200 UDIMM
MoBo: ASRock B550M Pro4
The Laptop (Lenovo Legion 5 15IAH7):
CPU: Core i5 12500H
RAM: 16GB (2x8GB) DDR5-4800
GPU: RTX 3050 Ti mobile
OS: Windows 11 Home
The Tablet:
Dell Latitude 7212 Rugged Extreme Tablet (Core i5 8350U/8GB RAM)
OS: Windows 11 Pro
https://linustechtips.com/topic/1569202-coil-whine-question/#findComment-16399795
thanks in advance
What was your previous PSU?  Using old PSU cables with a new PSU is absolutely not recommended.
https://linustechtips.com/topic/1569202-coil-whine-question/#findComment-16399798
https://linustechtips.com/topic/1569202-coil-whine-question/#findComment-16399799
The cause of the coil whine may not be the power supply at all, but may be the graphics card.
https://linustechtips.com/topic/1569202-coil-whine-question/#findComment-16399865
https://linustechtips.com/topic/1569202-coil-whine-question/#findComment-16399871
the sound does not come from the gpu but somewhere between the cpu and the psu (i got a fractal torrent case so the PSU is mounted at the top of the case)
https://linustechtips.com/topic/1569202-coil-whine-question/#findComment-16399914
PSU's can also have slight coilwhine.  My own RM750i has coilwhine as well.
Do you use an AIO that could maybe cause this sound?
https://linustechtips.com/topic/1569202-coil-whine-question/#findComment-16399932
psu and gpus can have coile wine and i think mb can also have it but mostly gpus and psus.
for gpus it gets more loud based on fps more fps the more loud it is. so limting fps can help but suxs to do it. in menus were you get get realy hi fps is were you mostly notic it. cant really fix it other then sell the gpu... you can get a more closed off case but that make it hotter so i dont no.
for psu is cheaper then a gpu in most case and can be replaced and since you got a mish mach psu ied recommend that. but first fined out witch it is.
other thing would be headphones i guess.
Edited by thrasher_565
https://linustechtips.com/topic/1569202-coil-whine-question/#findComment-16399936
