My ps4 has a broken case fan due to a hard fall. Since it has only one fan, there's technically no cooling. If I were to use a laptop cooler or case fans around the shell of the ps4, would they adequately cool my ps4?
Buy a new fan for it
Should just be a 92mm fan with a proprietary connector.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
You cant just put a laptop cooler on it. The case is plastic, and no heat gets transferred to the chassis for dissipation. You need a fan blowing air into it. Buy a new fan.
