I know that 8bits = 1 Byte
So is it 1 KiloByte= 1000 Bytes or is it not?
Edit:
So 1KB = 1000B
     1KB =1024B
     1KiB = 1024B
It just all depends on the number system. Generally which one should I use then???
https://linustechtips.com/topic/173831-question-about-bits-and-bytes/
yes it does.
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
Edit: @Fate, you sneaky ninja.
@Jaybird,@, you know you're both wrong, right?
Current rig: CPU: AMD FX-8120  Cooling: Corsair H100i  Mobo: ASRock 970 Extreme 3  RAM: 8GB 1333Mhz  GPU: MSI GTX 660Ti Power Edition  Case: Fractal Design Define R4  Storage: 2TB Seagate HDD + 128GB Crucial SSD  PSU: be quiet! 730W bronze
Oh so is it 2^10, cos it works as base 2. Ahhhh I get it now. So 1024b= 1Kb?
usually 1KB = 1024B, because this way it's just easier to do some calculations, and fits better how the computer works
but sometimes people mean 1KB = 1000B so, when possible, it's better to ask
if asking is not possible, then assume 1KB = 1024B
-snip-
Nope. They are right.
Kilobyte = KB
Kibibyte = KiB
1KB = 1000 Bytes
1KiB = 1024 Bytes
Edit:
Guys.... guys. You are all getting this so wrong.
Windows reads all storage in Kibibytes (don't ask why, it's complicated), but displays all storage as KB which is incorrect. A Kilobyte is 1000 bytes. A Kibibyte is 1024 bytes. It's different.
The "-bibytes" is used to talk about bytes that are 1024^X. The normal Kilo-, Mega-, etc are as they are meant to be. 1000^X representation.
So a Kilobyte is 1000^1, while a Kibibyte is 1024^1. A Megabyte is 1000^2, while a Mebibyte is 1024^2. And so on.
Edit 2:
If you want to know why it's different, it's because RAM manufacturer's measure RAM using 1024^X because... well, that's how computers work. In Bytes. Storage manufacturer's, however use 1000^X for other varying reasons.
When you get a 4TB HDD, you get a 4 Terabyte HDD. However, Windows reads that as Tebibytes (1024^4), and displays it as such, but with TB and not TiB. So it shows up as around 3.6TB even though it's really 4TB. You get all the storage you are supposed to.
However, if you buy a 4GB stick of RAM, you bought a 4 Gibibyte (4 * 1024^3) stick of RAM. That's what it will show up as in Windows because it's really in Gibibytes and is read as Gibibytes, but is shown with the GB and not GiB names/prefixes.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
not wrong just different response based on notation. see mister snow's post.
You sir have one sexy beard.
why thank you. It was birth though the trials of war were I and 30 men were fighting a legion of men stretched across a barren wasteland.
+1 for your profile pic. You are Italian, right?
Kilobyte = KB
Kibibyte = KiB
1KB = 1000 Bytes
1KiB = 1024 Bytes
oh, dididn't know that
apparently you're right, but the nonstandard notation for 1KB = 1024B is so [mis]spread, even by microsoft apparently, that my answer still stands: ask when possible, and assume 1KB = 1024B when you can't have more informations
thanks :D you too, right?
such compliments on the forum today. This makes me happy!
Yep, me too, o meglio anch'io.
Edit:
So 1KB = 1000B
     1KB =1024B
     1KiB = 1024B
1KB = 1024B and if i remember correctly, the 24 comes in because it is binary s and not decimal which consists of multiples of bits and byte. This is taught in probably the first thing they teach when you are learning to do binary and hexadecimal.
A water-cooled mid-tier gaming PC.
When dealing with computers use 1024. It only differs for storage where manufacturer takes a measurement of 1000 when building and Windows calculates it as 1024 so you never have the exact number of available space as specified on the box because of that difference but you still use 1024 because Windows is using it.
