Not the kind of infection I was expecting.
https://linustechtips.com/topic/163257-help-me-infection/#findComment-2171921
Looks like it cut deeper than the outer layer of the skin. It will be a little more sore than an usual cut, because it will take some more time to heal. At least that is what i think :P
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/163257-help-me-infection/#findComment-2171923
You should probably look up help from professionals if you think this is serious, not a bunch of geeks :P
I love StarCraft
Intel i5 4670 @3.4Ghz - Gigabyte G1 Gaming Gtx 970 @ 1542Mhz - 120GB Kingston SSD - 1TB Seagate HDD - Gigabyte B85-H3D - 8 GB 1333Mhz Kingston RAM - Azza Toledo 301 - SteelSeries Sensei/Logitech G400s - Razer Blackwidow 2013 Ultimate - Sennheiser HD 598 - Zalman Zm-mic 1
 http://www.last.fm/user/thalandros
http://www.mysteamgauge.com/account?username=76561198044810844
https://linustechtips.com/topic/163257-help-me-infection/#findComment-2171955
Doesn't look infected to me, if it's infected it will swell and you will see red streaks coming from it and moving across your hand towards your arm.
Man up and let it heal, stop poking/prodding around with it if you are, just keep the area clean and it'll heal.
https://linustechtips.com/topic/163257-help-me-infection/#findComment-2171960
Doesn't look infected to me, but the reason why it's not healing as fast as you'd expect might be due to it being on a knuckle that's always moving... but what would I know  :P
 alright then, hopefully :/
:( I'm scared
https://linustechtips.com/topic/163257-help-me-infection/#findComment-2171961
does it have pus? if so you need to see a doctor. Antibiotics are only available with a prescription.
Judging from the looks of it it doesn't look like it is infected. Try putting some medicated ointment on it and a band-aid. If it doesn't form a scab in a couple of days you might want to just call the a doctor and ask.
https://linustechtips.com/topic/163257-help-me-infection/#findComment-2171971
Don't be a baby I did this and broke foot yesterday I'm kidding about being a baby some of those small cuts hurt like a motherf*****, but no need to worry
https://imgur.com/foQtCX9 attaching the pictyre didn't work and man going to be first to post but mobile sucks
https://linustechtips.com/topic/163257-help-me-infection/#findComment-2171985
