..what? Steelseries doesn't make fans as far as I know.
I wouldn't get a h110 in the first place but would replace the fans if I did since the stock fans are pretty loud.
https://linustechtips.com/topic/157108-noctua-fans/#findComment-2093870
What would you get instead of an H110? just curious.
https://linustechtips.com/topic/157108-noctua-fans/#findComment-2093930
NH-D15.
https://linustechtips.com/topic/157108-noctua-fans/#findComment-2093963
NH-D15.
What if you had to get a AiO?
https://linustechtips.com/topic/157108-noctua-fans/#findComment-2093969
AIO just aren't that great. They're always louder and more expensive then similarly performing air coolers. And the best air cooler beats the best AIO by a couple degrees.
Fractal Design Define R4 | MSI x79a-GD45 | 3960X @ 4.6Ghz | Lots of EK Blocks | EVGA GTX780Ti 3GB | Corsair Dominator Platinum 16GB (4x4) DDR3 1866 | Samsung 840 Pro 512GB SSD | Western Digital Red 2TB x4 (Raid 10) | Corsair AX760 | Windows 7 Professional 64-bit
https://linustechtips.com/topic/157108-noctua-fans/#findComment-2094009
This is about looks not performance.
https://linustechtips.com/topic/157108-noctua-fans/#findComment-2094021
If I had to, I'd go with a Glacier 240L and put Gentle Typhoons or Noctuas on it.
https://linustechtips.com/topic/157108-noctua-fans/#findComment-2094022
Ok thx :)
https://linustechtips.com/topic/157108-noctua-fans/#findComment-2094026
The NH-D15 is better than most air coolers and AIOs. Like others have already said, the corsair fans on H100i/110 are noisy as hell. I would get either the NH-D15 or TC14PE. If you are on a budget then go for the TC14PE because it performs almost exactly like the NH-D15 while costing significantly less.
http://www.relaxedtech.com/reviews/noctua/nh-d15/8
https://linustechtips.com/topic/157108-noctua-fans/#findComment-2094867
If you had read my other post I said because of looks. Air coolers look like a gigantic piece of crap that fills the entire case. I don't care about performance. I want something aesthetically pleasing that does not block the view of my motherboard, ram, or graphics card. That is why I have an H100i. Plus the stock fans do not suit my colour scheme so I changed them.
https://linustechtips.com/topic/157108-noctua-fans/#findComment-2094903
idk man the fans on my H80i spin at 500rpm and keep my CPU under 55C at my OC. Also the D15 looks horrible.
https://linustechtips.com/topic/157108-noctua-fans/#findComment-2095108
When do the steel series come out and do you think they will cost more and would you replace the two 140mm fans that come with the h110.
I'd get the NZXT Kraken X60, it's also a 280mm AIO with a quieter pump. Slap two Noctua NF-A14's on it in pull and you're golden.
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/157108-noctua-fans/#findComment-2097687
I don't think AIO's even look good anymore, because everyone and their mum has one. Call me a hipster but I think a h100i instantly makes a pc boring now.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/157108-noctua-fans/#findComment-2097738
