what resolution is between 1920*1080 and 2560*1440 and also 4k and 1440p
220VoltsallCore
Go to solution Solved by jaslion,
1 minute ago, 220VoltsallCore said:
yes
Id say first try 3d render resolution and disable AA before changing actual resolution. As going under native res of the display will result in an unsharp image compared to a display with that native res.
Keeping the native res and just lowering the 3d render resolution keeps the image sharp as can be and will lower the load on the gpu by virtually decreasing the rendering resolution in game.
need to enable some custom resolution in between for better balance
tried manual but end up streched
What exactly are you trying to achieve by using a non-standard resolution?
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
1440p feels to low and 4k cause fps drop in rdr2
Do you have a 4k monitor or something?
Maybe try 1080p and set the scaling to integer in your GPU drivers. Higher non-integer resolutions can look way worse than lower integer resolutions.
From a quick google search the game seems to have a resolution scaling option. If that's true, that's your best option. Set it to 90% or 80% and the game will render at a lower resolution, but the UI will still render in crisp 4K.
yes
yes
msaa disabled. resolution scale you mean?
1 hour ago, 220VoltsallCore said:
yes
Problem is the panel is set for 4K with 3840x2160 physical pixels, so anything else than 4K and 1080p (which is just 1/4 of 4K) may look blurry due to not matching with the pixel layout
What's your GPU ?
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
What's your GPU ?
4060
34 minutes ago, 220VoltsallCore said:
4060
Running 4K on a 4060 is, well, optimistic to say the least... It's not even a good 1440p card due to 8GB VRAM
In this case, I'd just use upscale then.
| Ryzen 7 7800X3D | AM5 B650 Aorus Elite AX | G.Skill Trident Z5 Neo RGB DDR5 32GB 6000MHz C30 | Sapphire PULSE Radeon RX 7900 XTX | Samsung 990 PRO 1TB with heatsink | Arctic Liquid Freezer II 360 | Seasonic Focus GX-850 | Lian Li Lanccool III | Mousepad: Skypad 3.0 XL / Zowie GTF-X | Mouse: Zowie S1-C | Keyboard: Ducky One 3 TKL (Cherry MX-Speed-Silver)Beyerdynamic MMX 300 (2nd Gen) | Acer XV272U | OS: Windows 11 |
whats that integer scaling. i have no res scale for some games and they look bad in 1080p
any video on how to use it
Yes and well 4k on a 4060 is possible at low settings and older games. The 4060 is just a 1080p gaming card not at all meant for 4k in the slightest.
whats integer scaling it helps? i seen 1080 in mine look bad than other 1080p monitors
i play rdr2 high on 4k at 0.75 res scale and get 50+ fps
and current games like starfield,cyberpunk have bad graphics and still run bad.
I have 4k monitor, 3072x1728, aka 80% look good to me in games. Change it in game and not in windows/drivers.
More and more games have seperate display resolution and game/render resolution. Have display resolution at native resolution and change the render resolution. It looks better.
“Remember to look up at the stars and not down at your feet. Try to make sense of what you see and wonder about what makes the universe exist. Be curious. And however difficult life may seem, there is always something you can do and succeed at.
It matters that you don't just give up.”
-Stephen Hawking
Thats because you are NOT running at native res.
At 1080p 1 pixel has to take up 4 pixels on your screen and that isn't perfect so the image becomes less sharp.
You simply just have a low end gpu. Can't fix that fact.
so does 1080p look bad even in 1440p monitors?
If the 4k monitor and 1440p monitor is the same size, 1080p should look worse on the 1440p monitor than the 4k one, theoretically.
-Stephen Hawking
Any non native res wont look good.
Then there is also size of the screen, distance from it,... to take into account
shouldn't 1080p on 1440p look better than on 4k? since 1080p is closer to 1440p res
No, as one pixel on 1080 would be exactly 2x2 pixels on 4k, while on 1440p its not even close to a whole number of pixels, it would have decimals. I believe there would be one 1080p pixel per 1,333333....x1,33333... Pixel on 1440p. If my math is right.
-Stephen Hawking
