Budget (including currency): Any RTX 4070 Super
Country: Sweden
Games, programs or workloads that it will be used for:
My Current Setup:
CPU: Ryzen 5 5600 (non x version)
Motherboard: Gigabyte B550 Aorus Elite V2
RAM: Corsair Vengeance LPX Black 16GB (2x8GB) / 3200MHz / DDR4 / CL16 / CMK16GX4M2B3200C16
GPU: Gigabyte GTX 1660 Ti (want to upgrade to RTX 4070 super now)
PSU: Seasonic Focus+ / 550W / 80+ Gold
estimated power consumption according to PCPartPicker 399W
warning on PCPartPicker: "One additional PCIe 12+4-pin 12VHPWR power connector is needed." I think the PSU actually includes more power connectors but I need to check it out.
My question is if I should upgrade my PSU or if it's ok to use the 550W PSU for my RTX 4070 Super upgrade? I'm only using the GPU for gaming and have no need to overclock it for now.
Otherwise I'm also buying a "Cooler Master MWE Gold Fully Modular 1050W V2" that's on sale only today  (130 dollars now for some hours, usually 240 dollars in my country).
UPDATE!:  My 550W  powersupply has 2 PCIE 8-pin. Could I use these 2 for the 4070 super or do this GPU require more? I have 2  of these cables in the image below
https://linustechtips.com/topic/1567204-550-watt-powersupply-for-rtx-4070-super/
do you have the money to upgrade it? it should be fine since the 4070 is an efficient GPU and the 5600 is quite efficient too
estimated PEAK power consumption. In reality, unless you're doing a special workload, you won't be hitting ALL the components at peak at once
the 4070 should've come with an adapter for that power connector in the box, check if you've got it
that's quite a good price, can you spend the money? Or should I say, are you planning to upgrade your other components later on?
What resolution are you gaming at?
yes it's ok. the focus is Tier B and up so definitely
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
Country: Sweden
My Current Setup:
Your psu only comes with 2x 8pins, the 12vphr adapter needs 4x 8pins.
not for a 4070, each 8 pin is 150w. So 2 is already 300w. they need to get a better psu if they OC a lot but for now, I think it's fine
That said @PapaAquaWet the 550w focus won't leave you with much space to upgrade later on, so you could upgrade to this SeaSonic FOCUS GX-1000 ATX 3.0 1000 W 80+ Gold Certified Fully Modular ATX Power Supply (ATX3-FOCUS-GX-1000) - PCPartPicker
Total: £1040.95
The 4070/Super/Ti only comes with a 2x8pin 12vphr.  The RTX 4080/super comes with a 3x8pin to 12vphr and the 4090 comes with a 4x8pin to 12vphr 🙂
At most the FDB fan will go crazies and it will keep chugging along, this is a very good PSU for its heyday and still is. I had one back in the day in my mom's which I exploded like an idiot over shorting her unfinished rig... in a dumbest way possible. But that was truly a freak accident. That said, I'd simply push the "fan on" button on the rear and keep rocking. That CPU barely pulls 30-60W during a gaming session. On a PC that barebones, that card can well be handled by that PSU.
Hello! Thanks for you answer. I see that my PSU has 2 cables that says "PCI-E" on them. They have 6+2 pins each. So the 4070 super requires you to connect 2 of these cables for it to work right?
Yes, just look at the quote below from @Hinjima
So yes
I’ve got a 5600 and it pulls more like 75w during gaming at 35% load. And this is with a -30 undervolt. Definitely still fine for the 550w
Total: £1040.95
I'd be more worried about the fact that the Focus Plus had issues with modern cards than the wattage, but there's no point buying a new PSU until you know it doesn't work and since the 4070 has fairly modest power usage, you're more likely to be fine than not.
Sorry for the stupid question but are 2 of these cables shown in the image below enough for the 4070 super? I'm most likeley gonna buy this model of the 4070 super https://pcpartpicker.com/product/HCkH99/gigabyte-windforce-oc-geforce-rtx-4070-super-12-gb-video-card-gv-n407swf3oc-12gd
The GPU you are contemplating would use both 6+2-pin cables.
But you should consider the fact that the GPU specifications recommend a 700W PSU. https://www.gigabyte.com/Graphics-Card/GV-N407SWF3OC-12GD/sp#sp
If you don't want to use the adapter get the 4070 instead, since most of them (though not all!) use a single 8 pin.
Why does it say that 700W PSU is recommended? Is it only for overclocking purposes and or if you have a higher end CPU that draws more power?
The 4070 super seems to have better price to performance which is mainly the reason I go for it. Do you think a 4070 super will  be able to fit inside a Phanteks P300 case with the cable adapter that's included with the 4070 super?
Depends on the 4070. Phanteks says it has 330mm clearance (width shouldn't be an issue), so there are plenty of 4070 Super cards that will fit fine, but there also a large number of cards that will not fit.
Ok great! I'm more so worried for maybe the room between the motherboard and glass could be small
Nvidia specs recommends a 650W PSU (based on a 5900X CPU. My speculation is that the 3 GPU fans coupled with an allowance for less than good PSU installed in some systems encouraged the generous recommendation for the Gigabyte GPU.
The width of the case looks quite large from the specs I can find online, but I also can't find any guidance on how much space there is. If you can measure it, then you can check that against the width of the card.
Ok. I wrote to one of my friends and he said now that he recommends at least a 750W one so you have more headroom. I bought the PSU I saw on discount now "Cooler Master MWE Gold Fully Modular 1050W V2". Is it a good choice? I saw now that the " SeaSonic FOCUS GX-1000 ATX 3.0 1000 W 80+ Gold Certified Fully Modular ATX Power Supply (ATX3-FOCUS-GX-1000) - PCPartPicker" are also on sale now but it's 30 dollars more
I meassured by hand and it seems to be about 18-19 cm or 7 inches between the case and the glass. The GPU is 12.6 cm in height. The GPU I current have is a Gigabyte one aswell and it's 12.1 cm I see now so it should fit. The adapter hopefully will fit aswell.
The PSU you bought is a good Tier B model. It will be fine.
The Seasonic Focus ATX 3.0 is likely a Tier A unit.
Is it a big difference? Btw are those smaller pin like things on the 12VHPWR adapter called sens pins? I think I've seen them first on 3000 series cards or maybe 4000. What's the reason for them?
ok thanks. Last question I have are what are those small things on top of the "12VHPWR" pins called? they look like 4 small pins
They are "sense" pins and communicate the maximum allowable power draw.
