How to install (A)RGB fans?
Solved by NorKris,
30 minutes ago, tmz said:1. What is the difference between ARGB and RGB? (I haven't been able to find a clear answer by browsing the web)
ARGB = 5v, u can have different colors on the same led strip (aka control it)
RGB = 12v, same color the ledstrip. 4pins
2. How do I connect it in order to be able to control things like the colours? (My motherboard does have RGB headers. But I also read stuff about controllers and I'm really lost on this topic.)
you need an controller for ARGB, its 3 pins
if ur motherboard does not have ARGB u will need a controller like:
USB (with software)
IR (with remote)
buttons (on the unit or via the reset button on ur case)
