Dual 4k tv (worth it or not)
Ayush008
Hello guys
I hope u all r doing well
Please stay safe and healthy
I know many of you have quite depth knowledge regarding display stuffs, so I thought to take advise from you guys.
I m thinking to increase the size of tv in order to make gaming experience better by adding another 4k tv of same model
Does it worth it or not
No? You'll have a seem in the middle making any aiming and the like not possible.
Also driving 2x4k panels for gaming means you need a VERY high end gpu.
Just get a bigger tv if you want a bigger image
Thnx for your opinion @jaslion
What about  3rd person view
Multi Display gaming is really only worth it for racing or flying simulators if you're not into VR. For regular gaming such as FPS shooters, 3rd Person adventure games or 2D platformers, its nigh on useless and not worth it.
If you want to extend the viewing experience then maybe look at Ultrawide monitors.
Also, as @jaslion mentioned, 2 x 4k monitors will require a seriously high end GPU to shift all those pixels.
Bedroom PC - Lian-Li O11 XL Evo - Intel Core i5 13600k @ 5.4P / 4.4EGhz -  MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - Gigabyte RTX 4090 - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Living Room PC - Hyte Y60 - Intel Core i9 9900k @ 5Ghz -  MSI Meg Ace Z390 Mobo - 16GB Ram - Palit RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i7 8086k @ 5.1Ghz -  Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - EVGA RTX 2080ti - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office - Thermaltake Tower 100 - Intel Core i7 8700K @ 5.1Ghz - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - EVGA GTX 1080ti - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU + GPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Annex - Corsair 250D - Intel Core i7 3770k - Asus P8Z77 I Delux Mobo - 16GB Ram - EVGA GTX 980ti - 256GB Corsair SSD - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Office - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 980 - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 15TB Storage Server
Living Room AV Setup 5.1.4 - Yamaha RX-A2060 - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Yamaha RX-A1070 - 5 x Monitor Audio C265s (2 Zones)
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
3rd person view will still have a seam in the middle. Only way to get around it is 3 displays (or any other odd number)
Same thing the only time multi display gaming willnwork is if you have an odd number of screens so you have a center one for all the pointing at things.
Almost every 3rd and 1st person game uses the center of the screen for looking, aiming,... it simply does not work for gaming.
Also keep in mind multi screen gaming is NOT supported in all games even with the nvidia surround or amd eyefinity stuff enabled. Its just like a lot of games still do on ultrawides have black bars on the side as its not supported. Or run at a different resolution as its not supported.
Thnx for sharing your opinion @Blue4130bdw, if you would be at my place and suppose if you have high end gpu..what will u do, will you go for it
I already am in your position. I use a 65" tv 4k 120hz. Just a single one. It's big enough. I don't need more than one.
Same here bro, A95k Sony but I thought to bring some changes
Either get a bigger tv or keep using what you have. Adding a second tv will only worsen the experience.
Can you suggest me some better option
Budget?
Max size?
Neccesary features?
40 minutes ago, jaslion said:
Budget?
Max size?
Neccesary features?
Budget I can adjust somehow through savings
Well if we talk about feautres, I'm purchasing  only for gaming!! So I guess you can figure it out mate
But yes it should be worth it, I mean better than my current tv
That is up to you.
I wouldn't spend a lot of money replacing a REALLY REALLY REALLY REALLY good tv like the one you have. The only upgrade is size. You already have high refresh rate and a REALLY REALLY REALLY REALLY GOOD oled tv. In terms of image quality and such there is NO UPGRADE. The only thing you can do is just buy a bigger tv which will cost a lot of money.
Other than size there isn't any worthwhile upgrade you'll get from getting a different tv. You have pretty much a as good as it gets oled for gaming.
I am running my PC on my TV, only 55 inch though. I sit 8 feet from it. For me, another one would not be a good fit.
AMD R9 5900X | Thermalright Phantom Spirit 120 EVO, T30,TL-C12 Pro
Asus Crosshair VIII Dark Hero | 4x8GB G.Skill Trident Z @ 3733C14 1.5v
Zotac 4070 Ti Trinity OC @ 3045/1496 | WD SN850, SN850X, SN770
Seasonic Vertex GX-1000 | Fractal Torrent Compact RGB, Many CFM's
32 minutes ago, jaslion said:
That is up to you.
Well me the only point is size
Does it matter?
Or  waste of money
Was planning for my birthday
If you can find another use for the TV just incase you are not happy, I would go for it. But at some point you will realize that there is such thing as too much 😄
I used to run multi monitor, ehh.. its ok for smaller screens, but wagging my head left and right to see what's going on sounds like more of a chore than a joy.
Thnx brother @freeagent
For sharing your opinion
Bdw would you do kind to elaborate your point
Does it matter?
Or  waste of money
Personally I would say a waste of money as it's going to be at least 1700$ to get just a 65" better tv.
I wish I could afford 8k
For what?
At a normal viewing distance you can't see the difference between 4k and 8k. Our eyes literally arent good enough.
Also no pc right now can run native 8k games that are recent at quite high settings. the 4090 can get 60fps in a handfull but thats it those are exceptions
On 4/13/2024 at 5:09 PM, jaslion said:
Budget?
Max size?
Neccesary features?
@jaslion Still deep down my heart I know that there's an option, that's why u hv asked me
Kindly tell me please
This was before you told us what tv you had. The only upgrade you can have is size. If that is worth spending a lot of money then well a not too painfull upgrade a samsung s90c 77 is 3200$ at most usually and a bigger tv.
You won't get any improvements over the sony you have now except that the samsung is bigger.
They also have the 83" something s90c series one.
Keep in mind this is the diagonal size the length and height increase ENORMOUSLY when going up so mindfull that it fits. Also make sure your tv furniture or arm is rated for the WEIGHT!
