can I build my own NAS and use Synology OS ? legit ?
1: questionable. there's xpenology, but it's very much not supported by synology.
2: afaik hardware support is fairly limited on synology, because they only need to support what hardware they elect to use.
3: i dont think so, but there's no guarantees in unchanted terretory.
4: that's where #1's questionability comes in. you cant buy a license for the software, but there is no official way to install it on anything else than synology hardware. the question here is if the company has the recovery files to reinstall available for free, does this mean that the software itself is also free?
5: yes, but again.. uncharted terretory, no guarantees here.
i've dabbled with xpenology, and from experience i can tell you to use something else instead. it's a fun 'project' but long term there is zero guarantee that your NAS will keep running as expected.
