How cap Ryzen 5900X power draw to 100W max ?
Solved by NikolakiH,
18 minutes ago, Winterlight said:Should I keep it to 0 ? I don't know what is default values and after select PBO limit to manually I show everything at 0 by default. Btw if I lower to much PPT can PC not boot at all ?
You can just leave them at 0. 0 either means Automatic or Maximum, I'm not entirely sure which, but it would function the same regardless. I suppose if you lowered the PPT to 25 or below you could probably cause your system to become unstable, but within reason (60 or above) you should be fine. The Ryzen 9 5900 (non X) is just the same thing as the 5900X with a lower boost clock and PPT set to 88 by default.
