At a bit of a loss
"1080p60fps" doesn't really tell us much.
There is a big difference between 1080p60fps when using upscaling and running at lowest detail settings, and if you are running at native resolution with everything maxed out. It's also a big difference if we are talking about average FPS or minimum FPS.
The recommended specs for 1080p 60 FPS with medium settings is an Nvidia RX 2060 or AMD RX 6600 XT with a Ryzen 3700K, 16GB of RAM.
Judging by forum posts I've heard, it seems like an AMD 3600 with an RX 2060 is enough for 50-60 FPS with some settings turned down for 1440p gameplay.
Assuming that's okay for you, a brand new PC ends up being about 650-700 dollars. Here is an example of a build I quickly threw together as an example:
https://pcpartpicker.com/list/HmCW89
Please note that that's something I quickly threw together. There may be room for improvements.
You could also try and reuse some parts to get away cheaper. The PSU and the case might be reusable. That would save 110 dollars from my build.
It might be possible to reuse the motherboard, RAM and CPU as well although at this point I think it might not be a great idea to do that. They are quite old and would potentially hold you back.
