Beyerdynamic dt 990 pro (Rodecaster duo vs Sound BlasterX G6) best audio
Frankie128
Hi I have a question I recently bought a Rodecaster duo last year but I returned it I was wondering if the Rodecaster duo is better than the Sound BlasterX G6 for audio because I get a higher and better volume or maybe I was doing something wrong with the Rodecaster duo my headsets that I'm using are Beyerdynamic dt 990 pro I have two PCS and an Elgato wave XLR, Shure sm7b but I want to use one device to work for all can anyone help me or give me advice
Thank you... :)
buy an amp and use one of the products as a pre-amp?  The rodecaster duo only put's out 250mw but doesn't give any other specifications so I wouldn't count on it to power much.  The Schiit Magni+ and Heretic are on close-out right now, would be perfect.
Open-Back - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100 - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 *Hifiman R7dx
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero
Headset Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116
Class-D amp Topping A70
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
To play off of this for the 990 I would reccomend the magni over the heretic if you go this route. The 990 due to it being sharp sounds even sharper on op amp based amps I know the differences between the heretic and magni are subtle it's genuinely enough to avoid going with a heretic imo. Good Discrete power just sounds better on beyers.
Just bought the Rodecaster duo 2 days ago I wanted to ask will theSchiit Magni+ and Heretic still work with my roadcaster duo as an add-on
It's really difficult to say if it will work optimally but I can say it will work for sure.
The reason I say that I don't know if it will work "optimally" is because you don't want an amplified signal going into an amplifier.  However the output's with a speaker on them lead me to believe that they are line level because they certainly aren't powered enough to drive speakers.  (picture shown from sweetwater)
c99bdafd03wDeBmS6yWpo0fuIhIit5DClW7Q1ZMp.wm-dw.webp.2291edcffcdc347e3d3bf6e795805637.webp
The headphone out's are certainly powered and it looks like there are 4 of them?
I hate it when a manufacturer doesn't include specs that are thorough enough.  But I believe that a dual 1/4" TS to RCA cable will work for this when plugged into the output with a speaker.  This is my best guess.
The other 4 balanced look like input's.
DAC S.M.S.L SU-9
