Seeking Advice for Setting Up an Efficient Home Server in an Apartment
Solved by m9x3mos,
2 hours ago, MikeZ18 said:Hi, after some additional research I am leaning toward going down the diy route and use proxmox and truenas together. Although i really like the fractal node’s capabilities, the space I have in mind for it is only 33.5 cm which made the fractal node a little too wide. Do you have any other case recommendations?
I would check to see if any of the jonsbo n1 n2 or n3 might fit.
Silver stone has a small form factor case I think as well.
There aren't a lot of choices sadly.
