I do not get the FPS I should get, please help
Newman.-
So the last 2 years I got this pc specs:
  • Case:: CoolerMaster MasterBox MB311L ARGB
  • CPU: AMD Ryzen 7 3800X
  • CPU-cooler: Cylon 4F
  • RAM-: Corsair Vengeance Pro RGB SL16GB (3200MHz) and corsair vengeance pro rgb 16 gb ram 3200mhz, so 2 different ram groups
  • SSD: WD Blue SN550 1TB
  • Motherboard: Gigabyte Aorus B450M
  • GPU: Gigabite 4070 OC 12 GB
  • Psu: Aerocool Aero 80+ Bronze 650W
The problem I am facing is that I am not getting the fps  I should get. Since this week I replaced 3060 ti for the 4070 and still my fps sucks for the performance it should give. I mostly play Fortnite competitive and I never had this problem before. With low settings  and overclocking with ryzen master, afterburner, quick cpu I am getting around 200-300 fps... Meanwhile the same builds get around 300-400 and I get 200-240 in fights... Please help me... I do not know what is wrong....
xmp is already enabled for the ram sticks... pls help
The CPU bottleneck on 1080p.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
If I look my cpu up with lower cards or sth like that they get more fps, how is it botlenecking? Even if I compare it to a amd9 or better 7 gen my cpu comes out higher in games like Fortnite...
The secret solution they don't want you to know is in the spoiler below.
Don't be fooled, those videos of fartnite benchmarks can be misleading.
Turn the pretty stuff in the game back on.(Maybe play at a higher resolution too.)
Turn off the FPS counter.
Enjoy the bloody game.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1920x1440@65Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz
Gateway VX900 CRT: 1920x1440@64Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
issue number one!
also don't compare random yt videos to your system,  they are not the same system!
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
It's easy to explain. If your CPU can't feed the GPU properly, the GPU will work in a low(er) power state cause the load on it isn't high enough to warrant faster operation. Monitor your GPU usage.
